Standard Tesselated Geometry - 55.36 kB - 04/09/2021 at 11:18 |
ESP32 NextionDisplayCaseBack.stlBack cover for nextion control box print 25% FillStandard Tesselated Geometry - 36.70 kB - 04/05/2021 at 11:16 |
ESP32 Display Hinged Plate.stlSmall hinge part for display Tilt print 100% fillStandard Tesselated Geometry - 17.86 kB - 04/05/2021 at 11:16 |
ESP32 Display plate Hing.stlDisplay Tilt plate for new Remote display print 25% fillStandard Tesselated Geometry - 8.68 kB - 04/05/2021 at 11:16 |
10-CtrlBox.stlHousing for Main board print 25% FillStandard Tesselated Geometry - 158.82 kB - 04/05/2021 at 11:12 |
06-CtrlCover.stlCover for Control Housing print 100% fillStandard Tesselated Geometry - 1.45 kB - 04/05/2021 at 11:12 |
01-EncoderCover-Large.stlFits on back of Encoder housing Print 25% fillStandard Tesselated Geometry - 56.82 kB - 03/05/2021 at 15:48 |
02-EncoderHousing-Large.stlHolds encoder and fits on back of Nema 17 Print 25% fillStandard Tesselated Geometry - 49.50 kB - 03/05/2021 at 15:48 |
03-CenterDivide-ctrlEnd.stlDivides the space between the motor housing and the control box Print 25% fillStandard Tesselated Geometry - 26.25 kB - 03/05/2021 at 15:48 |
04-CenterDivide-batEnd.stlDivides the space between the two battery bays Print 25% fillStandard Tesselated Geometry - 8.29 kB - 03/05/2021 at 15:48 |
05-BatCover.stlSlide in cover for top of battery end Print 100% fillStandard Tesselated Geometry - 1.84 kB - 03/05/2021 at 15:48 |
07-BatTab.stlPrint 100% fill 8No. Required 4 per battery bayStandard Tesselated Geometry - 1.45 kB - 03/05/2021 at 15:48 |
08-BeltEndCover10mm.stlSmall cover to hold the belt end Print 100% fill 3No. requiredStandard Tesselated Geometry - 3.99 kB - 03/05/2021 at 15:48 |
09-BeltEndKeeper.stlPrint 100% fill 3No. requiredStandard Tesselated Geometry - 33.68 kB - 03/05/2021 at 15:48 |
11-MotBox.stlHousing for the Nema17 Print 25% fillStandard Tesselated Geometry - 122.05 kB - 03/05/2021 at 15:48 |
14-CtrlBoxCover.stlPrint 100% fillStandard Tesselated Geometry - 27.82 kB - 03/05/2021 at 15:48 |
15-FootBatLeftB.stlPrint 25% fill 3 shellsStandard Tesselated Geometry - 26.64 kB - 03/05/2021 at 15:48 |
16-FootBatRightB.stlPrint 25% fill 3 shellsStandard Tesselated Geometry - 26.64 kB - 03/05/2021 at 15:48 |
17-FootCtrlLeft.stlPrint 25% fill 3 shellsStandard Tesselated Geometry - 26.55 kB - 03/05/2021 at 15:48 |
18-FootCtrlRight.stlPrint 25% fill 3 shellsStandard Tesselated Geometry - 26.64 kB - 03/05/2021 at 15:48 |
19-SledCoverBottomV1.1.stlPrint 40% fill 3 shellsStandard Tesselated Geometry - 120.20 kB - 03/05/2021 at 15:48 |
19-SledCoverTop.stlPrint 40% fill 3 shellsStandard Tesselated Geometry - 137.48 kB - 03/05/2021 at 15:48 |
20-BatBoxLeft.stlPrint 25% fill 3 shellsStandard Tesselated Geometry - 75.38 kB - 03/05/2021 at 15:48 |
21-BatBoxRight.stlPrint 25% fill 3 shellsStandard Tesselated Geometry - 57.41 kB - 03/05/2021 at 15:48 |
22-RailConectorBatEnd.stlPrint 100% fillStandard Tesselated Geometry - 38.17 kB - 03/05/2021 at 15:48 |
23-RailConectorCrtlEnd.stlPrint 100% fillStandard Tesselated Geometry - 34.07 kB - 03/05/2021 at 15:48 |
24-break-body.stlPrint 100% fillStandard Tesselated Geometry - 7.41 kB - 03/05/2021 at 15:48 |
25-BreakSwitch.stlPrint 100% fillStandard Tesselated Geometry - 20.59 kB - 03/05/2021 at 15:48 |
