What this firmware can do for you:
  • Tracks all discovered ble devices or only the desired devices placed in a white-list
  • Selectively reads the battery level of tracked devices
  • Generates MQTT topic for an easy integration in you favorite Home Automation Hub
  • Mimics a lepresenced server to be integrated in FHEM
  • You can configure the devices to be tracked directly from the integrated WebServer without need to re-flash the firmware
  • Supports for OTA Update
  • Logs main events in order to identify problems.
