Power management section
A project log for Cheap RC Car : upgrade
Make it faster (no) and improve its range (yes) without breaking the bank
Christoph TackChristoph Tack 07/01/2021 at 19:480 Comments
Power distribution board
The power from the Li-Ion is connected to the leftmost JST-EH.  There's a 2pin JST-EH for the power-interruption switch between the battery and the battery protection board.  It might be wiser to connect the battery monitor circuit directly to the battery and then put the power-interruption switch.  I'll have to find out later.
The three bottom 3-pin JST-EH connectors connect to the two boost converters and to the ESP32.
Li-Ion protection
A test using 2x 1S/3A-Li-Ion protection from AliExpress (€0.30+€1.15 shipping) showed that it was inadequate.  The current limit is too strict.
A better option would be to order this battery monitor system (BMS) instead.
Top view
Bottom view
Motor Power supply
The traction motor will run on 12V, the steering motor on 7V.  Two boost converter modules will be used.  The quality of those modules is not great.  One gave hiccups when the traction motor went full power.  Replacing the module was the quickest fix.  I bought them as MT3608 boost converter modules.  The label on the package is "XT1208".
Power management board and two boost converter modules mounted into the battery compartment.
The two boost converter modules are fixed with 3M VHB-tape.  It sticks well.  It's thick so it can be used on uneven surfaces.  It's also easy to remove.  It doesn't leave traces of sticky glue (unlike duct tape which is a hell in this regard).
