AEMLIC can also charge 4.0V and 4.2V LICs
A project log for Solar harvesting into Lithium Ion Capacitor
A tiny board with AEM10941 solar harvesting IC charging a Lithium Ion Capacitor
jasper-sikkenJasper Sikken 05/13/2025 at 18:250 Comments
Previously Lithium Ion Capacitors (LICs) were 3.8V, however recently there are 4.0V and 4.2V LICs, and they have huge capacitance 1100F and 1300F. In another log I have tested capacitance and leakage of these huge LICs.
Cda LIB1840Q4R0118 1100F 4.0V
 BT LIC1840H4R2C1300 1300F 4.2V
In AEMLIC the charge voltage is set using 4 resistors and the values can be calculated using a spreadsheet found on E-peas AEM10941 product page. To test charging to a higher voltage I have adjusted a AEMLIC resistors R1 and R2.
to following values
In picture above) you see the disable voltage (~2.50), the enable voltage (~2.6V) and the charge voltage (~3.8V or ~4.0V or ~4.2V) and the resistor values. Always use 1% resistors. I have tested and confirmed AEMLIC is able to charge to these voltage levels. I do not recommend changing these resistors because you need serious soldering skills for these 0402 size resistors. I don't support questions about changing these resistors.
