Airspeed sensors are quite expensive, while barometers are cheap. So why not making an airspeed sensor using 2 barometers?
front shell v3.stlStandard Tesselated Geometry - 587.68 kB - 04/11/2021 at 14:13 |
case.stlStandard Tesselated Geometry - 177.91 kB - 04/11/2021 at 14:13 |
baro cover.stlStandard Tesselated Geometry - 8.48 kB - 04/11/2021 at 14:13 |
PickAndPlace_PCB_barometric pressure_2_2021-03-11.csvComma-Separated Values - 5.29 kB - 03/11/2021 at 20:17 |
BOM_PCB_barometric pressure_2_2021-03-11.csvComma-Separated Values - 3.17 kB - 03/11/2021 at 20:17 |
I designed and 3D printed the case and mount for the PCB. (it should be a 2h print.
I attached the files for it.
I also tested the sensor while driving around for an hour (I was on the passenger seat ;) ):
Next step it is flying it, but this one will take a while unfortunately (I am waiting for a few pieces to get my plane back in order)
I received the PCB and wrote the code for it, first results are promising.
First results:
Next steps:
