First Assembly
A project log for Mothra: Acoustics Laboratory on a Stick
STM32WB55 host with microphones and accelerometers and lots of memory for vibration and sound analysis
kris-winerKris Winer 03/12/2021 at 22:360 Comments
03/08/2021
It's always fun to get the first boards from OSH park and spend some time assembling them. This is when you find out what dumb mistakes were made in haste. And of course, after putting two of the Mothra.v01 pcbs together, I discovered that I had swapped VDD and GND when connecting the power-control LDO to the NAND flash.
I had to remove the LDO to avoid the resultant short. This means that every component on the first version except the NAND flash should work as designed or at least be testable.
You can see the trace fanout on the bottom layer for the QSPI IIS3DWB and SPI SD Card et al. The design rules "require" that all traces route out of the bottom of the module such that the area to the right (in the above image of the board bottom, the area bottom left) of the module remain free of components and signals and be covered with ground plane and vias. This makes the trace traffic mighty congested even on a four-layer pcb; the second and third layers look about the same as the bottom one.
The STM32WB5MMG module embeds a STM32WB55VG 100-pin WLCSP and there are 85 total pins in the small 7.3 mm x 11 mm module.
I was worried that the 0.435 pitch pins on the periphery might be hard to solder. However, I found it was surprisingly easy using my usual 26 gauge syringe with low-temperature solder paste and a combo quartz heater plate and hot air gun.
This was my first experience using 0201 passive components. Three sensitive pins require 3.3 nF filter capacitors near the module, which are recommended to be 0201 (or smaller!)  Somewhat to my surprise, these were as easy to use as  the 0402 passives I regularly use.  I am tempted to start using this package size more often, especially in very small designs.
I remember when I ordered some 0201 caps by mistake years ago (I still have them) and thought "there is no way I could ever make use of these!". What seemed impossible then will become a matter of course soon enough...
The fix to the botched circuit was easy to affect and we should have Mothra.v01a pcbs available soon. In the meantime, we are testing what we can using the wounded boards.
