Taking it apart (mostly)
A project log for Old 3D Printer = New Laser Cutter
Converting an old CubeX Duo 3D printer into a laser engraver/cutter.
a-a-wA-A-W 03/13/2021 at 23:440 Comments
I took off the outer plastic casing and most of the extrusion assembly. I also removed the print bed and the Z axis, along with the filament tubes. I unplugged and took out the motherboard at the end.
Next up, attaching a laser. This will probably be a while as I have some other important projects to work on first...
