Prospective Opto Replacements
A project log for Forced air HVAC Smart Pseudo-Zoning
Overcome temperature imbalances in homes with forced air built before modern HVAC design using a variable speed booster fan.
ecpcEcPc 03/16/2021 at 02:150 Comments
I'm using the H11AA1 for everything because... I got it to work... and then yeah i just used it in every position in every iteration. I told myself this was good because "it reduces part count". I'm ordering 10, not 10 million but I was just lazy.  Time to for baby bird to leave the nest and find some new components.
My home base:
https://www.vishay.com/docs/83608/h11aa1.pdf
24 VAC signals from thermostat:
This looks like a suitable analog... but requires an order of 1000 from digikey. Just not ready for that level of commitment.
https://www.vishay.com/docs/83726/tcet2600.pdf
This has similar properties and I don't know the ins and outs
https://www.vishay.com/docs/83523/k814p.pdf
Fan tachometer and 10V PWM:
Thinking about this one:
https://www.vishay.com/docs/81135/K827PH.pdf
