Video on the module
A project log for Dual 7 Segment Hex Display Module
Two digit (8 bit) hex display using a PIC16F18446 microcontroller
john-lonerganJohn Lonergan 05/04/2021 at 11:140 Comments
During recording I noticed a bug in the display - likely the software - it's possible to see in the vide. Easy to fix and I might also add a latch function when fixing it.
