Progress has resumed...
A project log for Propeller P2 Retro Games Project
An Intel 8080 emulator running on Parallax Propeller P2 hardware designed to emulate retro arcade hardware
graham-coleGraham Cole 09/05/2021 at 09:450 Comments
I hate it when real work gets in the way of my project but it has or at least it was. Things have calmed down a bit so I am able to give you an update.
Quite a few of the component parts of the cabinet are two piece and have to be glued together before assembly.
I had a few mishaps with alignment when gluing some of the two piece components so I ended up making jigs for them, they worked great!
This has enabled me to get all the two piece components glued together and I've now completed all of the LCD assemblies.
