The cabinet
A project log for Propeller P2 Retro Games Project
An Intel 8080 emulator running on Parallax Propeller P2 hardware designed to emulate retro arcade hardware
graham-coleGraham Cole 06/06/2021 at 19:500 Comments
The arcade cabinet design is based off this project by TobiasPi https://instructables.com/Mini-Pi-Powered-Arcade-Machine/
I will be releasing the full design plans for both styles of cabinet under the same terms as the original project (CC BY-SA 3.0 license).
creativecommons.org/licenses/by-sa/3.0/
If you have access to a laser cutter and some 3mm birch plywood then you will be good to go.
