LucidVR Budget Haptic Glove
A functional glove that lets you use (and eventually feel) your hands in VR.
Public Chat
This is a project to try to make VR Haptic Glove technology more available for the public. Currently, most VR Haptic Glove products out there are extremely expensive and are targeted for commercial use. In starting this project, I wanted to create a budget, but still well-functioning VR Haptic Glove that's cheap and easy for people to get their hands on (or in, lol).
https://www.tiktok.com/@lucas_vrtech
https://www.youtube.com/c/lucasvrtech
https://discord.gg/YE3ddNk6
Prototype 3 cost me $21.89 in *unit cost*, in parts, that's less than $11 per hand!
Originally, this was just a fun quarantine project to keep me busy, but 300,000 followers later, this project is now much more than that. My goal now is to spread this project as far as possible and hopefully help more people fall in love with Virtual Reality.
Currently, the project is in prototype 3.1 but I'm innovating constantly to improve the gloves. Adding FFB haptics in Prototype 4.
Prototype 3 of the LucidVR glove. This is a finger tracking glove that allows you to use your hands in VR. Follow along with my developments on this TikTok page:
Currently, the glove is compatible with PCVR headsets through SteamVR.
I've tested the gloves on:
* Oculus Rift CV1
* Will be testing on Oculus Quest 2 (w/link) soon
Resources:
Wiring Diagram: https://github.com/LucidVR/lucidgloves-hardware/wiki/Prototype-3-Wiring-Diagram
Parts List: https://github.com/LucidVR/lucidgloves-hardware/wiki/Prototype-3.1-Parts-List
Arduino firmware and STL Files (for 3D Printing) are located here: https://github.com/LucidVR/lucidgloves-hardware
Open-source driver to use the gloves in SteamVR (A collaboration between Danwillm and me):
Github Driver Link
Steam Driver Release
Instructions and video tutorials for assembling the gloves are coming soon.
WARNING: THIS PROJECT IS STILL VERY EARLY IN DEVELOPMENT AND THINGS WILL BE CHANGING.
Many features may be unstable until they are polished, build at your own risk :P
Roadmap:
Prototype 1 (Unreleased)
  • The genesis of this project
  • Super bulky and unreliable
Prototype 2 (Unreleased)
  • A huge upgrade over prototype 1
  • Reduced bulk and more reliable
Prototype 3 (Released)
  • First public release
  • Much more comfortable and tracking improvements
Prototype 4 (WIP)
  • First public Force Feedback prototype
    • Addition of haptic servos (already demonstrated on tiktok)
  • It Will most likely be very bulky, will reduce bulk in Prototype 5
  • Bluetooth! + Steam Release
    Lucas LucidVR05/21/2021 at 22:22 0 comments
    Alright, so all of the pieces for using Bluetooth with the VR gloves have come together!
    Using Firmware V2 and Driver v0.3, the gloves can now communicate to steam completely wirelessly.
    This requires using an ESP32 development board instead of an Arduino nano on the glove side.
    Change COMMUNICATION to COMM_BTSERIAL in the firmware, and communication_protocol to 1 in the driver.
    Currently, Bluetooth communication is done through Bluetooth Serial, but I will also be writing a BLE implementation later on.
    In other related news, the open-source VR glove driver that I have been working on in collaboration with Danwillm is now finally released on the Steam store!
    https://store.steampowered.com/app/1574050/OpenGloves/
    I recommend using the steam release of the driver instead of the GitHub zip, as you will get auto-updates as they roll out.
    I'll also be releasing a video tutorial on how to build and set up Prototype 3.1 very soon!
    Youtube Channel
View project log
sachitbisht874 wrote 6 days ago point
How close are you to releasing V4?
sithkiller66 wrote 06/11/2021 at 16:55 point
Will the parts from V3 be compatible with V4? And some games use buttons for say dropping a mag or for slo-mo, how do you create button inputs without buttons
Galacticnoob wrote 06/10/2021 at 23:44 point
I'm planning on building these and I but a parts/cost list together and idk why but with everything ( I chose the Bluetooth option and went with joysticks but not a/b buttons) it came out to $55.89, even though I found the cheapest cord and cheapest gloves for it.
InKey wrote 06/14/2021 at 04:11 point
strange i found what i need for 22
did you make sure to check aliex?
Ratrodjoe30 wrote 5 days ago point
did you happen to buy one for each hand
StrikeIsMe wrote 06/10/2021 at 14:52 point
Is there a possibility that this could come to Oculus Quest 2 anytime soon? Without link I mean.
No never, unless oculus buys him
Eric Geer wrote 06/10/2021 at 00:39 point
Have you considered using optical encoder rather than potentiometers?  I can see you saving quite a bit of bulkiness using them.  A ribbon instead of a string and optical encoder, with a rubber band pulling on the ribbon would make this design super low-profile 100% linear design and even cheaper in electronics!
Ethan wrote 06/06/2021 at 11:27 point
what if you were to add a locking mechanism for when you were having collisions with objects or whilst holding an item. (small moters that cannot hurt us by pulling back to far.)
Lain Szvahl wrote 06/02/2021 at 04:13 point
Aloha!, Seems the Discord link has expired or something. as its no longer valid
InKey wrote 06/01/2021 at 23:59 point
Can you Please add a Lone echo/Oculus Mod
Your Gloves will work perfectly in lone echo
sans9929 wrote 05/29/2021 at 23:34 point
are the goves quest 2 compatable
Jordan wrote 05/09/2021 at 23:32 point
Is there an updated Discord link?
Lucas LucidVR wrote 05/21/2021 at 22:13 point
updated
Tony wrote 05/04/2021 at 05:49 point
Ignore everything after this. I was unable to get the bend sensors to function.
I just found an extremely interesting project that could probably be adapted to fit this project with some tweaks. It would be extremely cheap and easy to construct, although I'm not sure about longevity or accuracy: https://www.reddit.com/r/arduino/comments/n4dvr5/make_your_own_bend_sensor_with_no_cost/
I will try it myself as soon as I get a chance and leave a reply with how it ends up working
ozorisx wrote 04/24/2021 at 18:02 point
is there anything i can do about the 3d printing ?
I don't have access to 3d printers in my country for cheap to make it viable
Isley wrote 05/10/2021 at 04:12 point
On his discord, I noticed there are some people willing to print out parts and send them to you. maybe try there?
einar.petersen wrote 04/22/2021 at 08:40 point
Another question: Any possibility of paying to get a couple of finished builds 2-3 pairs? If yes - How much would a build be.
einar.petersen wrote 04/22/2021 at 08:38 point
@Tony thanks for the reply - Now I need to go back to GODOT and figure out if they do "index controller" mapping in their VR setup.
FlemShark wrote 04/19/2021 at 03:38 point
anyone else having troble getting the nuts in the tensioner part at defualt size
Lucas LucidVR wrote 04/20/2021 at 03:23 point
Try the prototype 3.1 tensioner, it has a bigger slot for it
FlemShark wrote 04/20/2021 at 03:24 point
ok thank you
Silverwebb wrote 04/18/2021 at 23:35 point
hi, will those glove works for Value Index VR and VRchat?
Yes
Trey wrote 04/18/2021 at 00:36 point
Got a question, I don't have enough knowledge on the topic, and it may be different than the intended purpose of being able to interact with an actual vr headset, I want to be able to use them in order to interact with a computer, so like record gestures and then it does something essentially, would the vr controllers from a vive or quest themselves still be needed?
Tony wrote 04/21/2021 at 16:02 point
The controllers are only used to track the gloves in 3D space, they are not necessary for the finger tracking. If you wanted to use it in the way you describe you would need to find software that can already do that (which I doubt has been made) or write your own software for it.
Egor wrote 04/16/2021 at 17:49 point
Hello, your decision for new VR gloves looks interesting, but it can be improved too. I have a couple of ideas. One of them: you can replace your method of blocking the thread movement with a more elegant one. Namely: use a stepped motor to lock the spring itself, not thread movement. This will allow you to directly change the length of the thread and block the movement of the fingers. Also, with the help of this, it will be possible to easily recognize the current position of the fingers. In addition, this is a less aggressive method, and even if you overdo it, you will not be able to pull the threads more than you might be able to. In your decision, you can break the motor. You can write to me in a telegram, I will explain in more detail. @JackyLuck
einar.petersen wrote 04/15/2021 at 17:09 point
This looks a very interesting project along the lines I had imagined possible, I definitely might consider using something this for my project involving visually impaired - Can you tell me what kind of API is available if I wanted to integrate use of these gloves as controllers in a project I am likely to be using the GODOT platform to develop https://godotengine.org
Tony wrote 04/21/2021 at 16:04 point
Afaik the software is a driver integrated into SteamVR. Assuming your game is a VR game, you would use it in the exact same way you would use an index controller
Daniel wrote 04/15/2021 at 14:03 point
I have seen your latest update! Awesome idea! But did you thought of using solenoids to block the rotation instead of servo motors? They would work much faster :)
