Why we think this 1U rackmount is unique
  • It‘s based on our gen.3 rackmount, you can find the project here. This makes a great alternative with added Power Over Ethernet (PoE) support.
  • We’ve made the 0.91 inch OLED display a bit different, it will turn on automatically and read the stats (CPU/Memory load, IP address, temperature, etc. ) as soon as Rapbian’s booted up.
  • Micro SD card slot, power LED and the two HDMI ports are all brought to the front.
  • With the Power button, you can easily reboot your Raspberry Pi with a single push. There’s also an LED inside the switch.
  • We also converted the two micro HDMI ports into normal ones.
  • It’s compatible with any server racks in the market.
What we are considering after this:
  • A 2U rack mount supporting up to 12 Pis.
  • Rpi-only cluster racks (maybe)
  • Rpi-only NAS cases (maybe)
