ddamp_bpedal_hihat.f3dFusion 360 project for the bass pedal + hihat assembly.fusion - 667.87 kB - 05/30/2022 at 16:46 |
ddamp_foot.f3dFusion 360 project for the drum frame foot.fusion - 133.94 kB - 05/30/2022 at 16:46 |
ddamp_drum_foot.stlFoot for the drum frame.Standard Tesselated Geometry - 774.59 kB - 05/30/2022 at 16:40 |
ddamp_bpedal_hihat_front.stlFront part of the bass pedal assembly.Standard Tesselated Geometry - 693.05 kB - 03/16/2021 at 14:02 |
ddamp_hihat_back.stlBack part of the hihat assembly (that is attached to the bass pedal).Standard Tesselated Geometry - 525.57 kB - 03/16/2021 at 14:02 |
ddamp_hihat_front.stlFront part of the hihat assembly (that is attached to the bass pedal).Standard Tesselated Geometry - 474.40 kB - 03/16/2021 at 14:02 |
ddamp_bpedal_hihat_back.stlBack part of the bass pedal assembly.Standard Tesselated Geometry - 402.04 kB - 03/16/2021 at 14:02 |
connector_front.stlFront linking element between the bass pedal assembly and the hihat assembly.Standard Tesselated Geometry - 51.45 kB - 03/16/2021 at 14:02 |
connector_back.stlBack linking element between the bass pedal assembly and the hihat assembly.Standard Tesselated Geometry - 49.89 kB - 03/16/2021 at 14:02 |
