First prototype pack testing
03/22/2021 at 21:21 • 0 commentsWith the pack built, it was time to test. The first thing I noticed was that the pack had no output voltage. This is normal because while building it, you can't really attach both cells at the same time, so the protection chip decides that one of the cells is low/missing and turns the output off. The condition is cleared by providing some charge current to the pack. At that point I saw 6.6V on the JST VH connector.
Time to put the pack on my electronic load and put some load on it. The pack was designed for 4A max output. Let's start with a 2A load:
The thermal image shows a minor 4 °C temperature increase at the current sense resistor and dual MOSFET that disconnects the pack if there are issues. My calculations indicate that at this current level, the power parts would dissipate about 0.17W.
Let's crank it up to 4A load:
As expected, more heat at this load. But very reasonable! My calculations indicate that at this current level, the power parts dissipate about 0.7W. There's enough power dissipated that the pack warms up a bit, so comparing to the previous baseline, the temperature increase is about 26 °C. This is at ~24W output power!
There has to be some voltage drop across the current sense resistor and protection MOSFETs, resulting in some losses, because the pack protection chip uses this voltage drop to protect against over current and short circuit. The over current detection threshold is at 0.2V.
Since there are tolerances on the detection voltage, the current sense resistor and especially the RdsON of the MOSFETs, the component selection was done to end up with a over current detection range of 4A - 5A. The goal is for the threshold to be above the maximum advertised current (4A) and the maximum current supported by the cells (5A). My prototype pack had protection kick in at 4.6A.
I let the pack run down to empty to check the under voltage cutoff. I had specifically made the pack with some cells that I had abused before to have some differences between the cells. If one cell has less capacity than the other, it's easier to observe that the protections work correctly. In this case, one cell reached 2.0V while the other one was still at 2.7V, and the pack correctly disconnected. Success!
At that point I started to charge the pack with my bench power supply at 7.2V with a current limit at 1.5A. Both cells quickly recovered to 3.4V. Near the end of charge, when voltage starts to increase again, I reduced the current limit to 0.2A because that's the level for which the balancing circuit is designed. Why only 0.2A? Because we are using passive balancing, we just burn off excess power to prevent one of the cells from being overcharged if the other isn't full yet. Because this may happen for instance in a outdoor box out in the sun in Arizona in summer, we don't want too much power to be dissipated for fear we get the cells too hot. With the current component values we dissipate 0.72W when balancing a cell.
Here is a thermal shot when one cell is full and passive balancing for it kicks in:
The temperature increases by 14.5 °C where the balancing resistor is located.
In this picture both balancers have kicked in:
This increases the board temperature by about 35 °C. Of course, having both balancers on is not really a mode that's normal if you're using a real charging chip. Both cells are full at this point and the charger is supposed to turn off. But my bench supply of course happily will keep sending 0.2A through the balancing resistors. :)
All basic pack protection functionality seems to work as expected! Very happy with the progress.
03/22/2021 at 20:10 • 0 commentsOnce I had PCBs it was time to make a pack. I already had nickel strips and a spot welder from previous efforts, so that made things easier. I also got flexible silicone wire, JST VH terminals and housings and a crimper that works for JST VH.
First I soldered the wires and nickel strips on to the PCB:
Then I spot welded the nickel strip to two 18650 LiFePO4 cells:
As you can see, the components sit in the gap due to the radius of the two cylindrical cells to get a compact assembly that only takes up the space of two 18650 cells:
One of the parts you see at the end is an NTC thermistor. Since it's supposed to measure the temperature of the cells, the air gap is not ideal (although once the pack is wrapped, the air being trapped in the pack should improve things versus open air). I asked a manufacturer in China I'm talking to about mass producing these about filling the gap with some thermally conductive compound and they said it was possible.
A real battery pack would at this point be covered with foam end caps and wrapped in heat shrink, but since these are prototypes and I will likely be messing with them, I decided to leave that off for now.
First prototype PCB
03/18/2021 at 03:13 • 0 commentsSo I've been working on this for a while already and am only now catching up in documenting it. I document it because it might be useful to someone but also because it tends to be useful to myself, if I need to check back later on what exactly happened, when, or why I did things a certain way.
I think it was last week that my prototype PCBs and parts for the first 2S LiFePO4 BMS arrived and this effort really started to accelerate. Here are some pictures of the prototype build:
This was a small panel with 5 identical circuits (3 left in the bottom picture).
Each circuit has roughly two parts to it: on the right there is the fairly standard pack protection and balancing. It uses two HY2212 chips with MOSFETs and 18Ω resistors to burn off excess energy if a cell reaches 3.6V. The resistor value makes it so only 200 mA can be burned off, to keep resistor wattage/cost and heat generation in check. This means that when we reach that point, the charger should only try to put in 200 mA max, because otherwise the cell will still get the remaining current. So the charger has to take part in this for it to work. Then there's also an HY2122 chip which takes care of protecting the pack from over voltage, under voltage, over current and short circuit. It uses Q1, a dual, drain connected MOSFET to turn charging and discharging on and off. It normally measures the voltage across this dual MOSFET to determine current limits, but I decided to have lower RdsON MOSFETs and add resistor R1 to make these limits more predictable since RdsON of MOSFETs can vary quite a lot and the limits depend on the total resistance. As you can see, I messed up the part I bought so there's a 2010 size resistor where there should be a 1210. Oh well, it still fits. :)
The left side of the circuit is where most of my "special sauce" is. The SO8 chip is a Padauk PMC131 microcontroller, which implements the 1-wire digital interface in software, contains the pack ID data and can measure the two NTC thermistors. Yes, I admit it, I like these little Padauk micros. I used one very effectively in my #wESP32. This one has a little more oomph and costs a little more than the 3¢ PMS150C that made them famous, but you still get a lot of value for the price. In this case, a 12-bit ADC and -40°C to 85°C temperature range.
To be honest, I had some trouble making the 1-wire protocol work in this chip. Unlike some other protocols, 1-wire is very dependent on timing, with a 1 being a short pulse and a 0 a long pulse. It took a good deal of optimization to make everything execute fast enough. I also ran into an issue because I was testing the code using a MicroPython 1-wire host running on a Raspberry Pi Pico, and it turns out that the timing of the MicroPython onewire library is just wrong. It doesn't respect the minimum bit slot time of 60 μs. It also doesn't wait for a low bus to be released before it starts pulling it low for the next bit, but just clobbers through what the slave is doing. I forked the code, fixed it and flashed my own version and then it worked. I should do a pull request to get this fixed upstream, but the fact that there are currently 377 open pull requests doesn't make me feel optimistic that it would be useful. I should still do it though.
R7 on the far left and R8 next to the balancing resistors are both NTC thermistors that are measured by the micro, and their value in a resistive divider can be read over 1-wire. I have two of them to hopefully be able to tell more about the pack state. R7 is far from the balancing resistors and R8 is right next to them so I hope to be able to tell from the temperature gradient when one of the balancers kicks in.
The components and wiring pads are all clustered toward the center of the PCB because I want them to face inward and end up in the gap between the cells. To make some use of that wasted space between the cells that offends me. ;)
Choosing cells
03/18/2021 at 02:18 • 0 commentsWhen I started this project, I started by talking to some Chinese folks who are in the business of making battery packs. I'm new to that side of the business, so I wanted to learn as much as I could. One important thing was to figure out the type of cells available.
I have always felt like a pack made with round cells seems like it's a bit of a waste of space. There are always empty gaps between the radii of the cells. So I started by telling them that I was looking to make a small 2S LiFePO4 pack, and I would like them to find suitable cells. And if possible, I would like LTO cells of a similar size , so that I could make a 2S LiFePO4 pack with similar physical dimensions as a 3S LTO pack.
I never found anyone who could help me with this. Oh, if I would order 30000 of them, they could make a custom cell for me, but below that volume, forget it. Unfortunately, my business isn't at that volume, yet. ;)
At that point I was like: "Oh forget about making a LiFePO4 and LTO pack of the same size, what size LiFePO4 cell do you have that would work for me?" I was sent some options, but to be honest, options were limited. Turns out LiFePO4 cells are more often made in larger sizes than smaller sizes, to make car batteries, golf cart and electric bike systems, things like that. High power stuff. Then I requested specs for the few cells they could offer me in smaller sizes, I was in for a surprise when I did some calculations.
I calculated the capacity of a pack per unit of volume (energy density) for a pack made with the pouch cells I got specs for versus one made with 18650 cells, and was surprised to find that the energy density of the pack made with 18650's was actually better than one made with pouch cells! That was completely unexpected. How can that be with all that wasted space? Well, I already knew there are cells optimized for energy and others optimized for power. I have always used the ones optimized for energy, and it turns out pretty much all LiFePO4 pouch cells are optimized for power, to be used in high power applications. I can't get any pouch cells optimized for energy it seems. So standard cylindrical cells are going to be the best for me it seems.
The good thing about that is that there are many factories that make them, so I won't be stuck with a single manufacturer. They exist for both LiFePO4 and LTO. If I want a pack that's equivalent in physical size between LiFePO4 and LTO, I make a 2S3P LiFePO4 and a 3S2P LTO (or multiples of that). Another benefit is that I already use 18650s so it makes things easy to prototype. And because they are pretty standard, it's easy to plan different capacity packs by using multiple cells in series and parallel. So in some ways, ending up back with standard 18650s has simplified this a lot.
​Trying to plan for the unknown
03/17/2021 at 22:17 • 0 commentsThis is an important development for my company. So I want to give it thorough thought because I may have to live with the consequences of decisions I make now for years to come. On the other hand, if this effort has taught me anything it is that there is such a thing as overthinking it. By trying to plan for everything, and think of everything that may ever be necessary, you end up just spinning your wheels and nothing ever gets accomplished.
So once I had done that for a couple of months, it was time to bring this back to reality. The first thing was to list what were important aspects to me from a high level, "platform" point of view. If I was now going to start making "LiFePO4wered" battery packs, what did I want from them? What did I want my customer's perception to be? Here are some important things I considered:
- Voltage. I love the fact that the useful LiFePO4 voltage range perfectly matches the voltage range of many 3.3V chips. This is great and makes for very efficient power systems, and I will keep producing boards that support this for low power systems, but that's not what this effort is about. This is about powering SBCs and other "higher power" systems, and I need a higher voltage to keep up with their power requirements. Most of them nowadays require 5V input, although as they get more and more power hungry, that may change in the future.
On the #LiFePO4wered/Pi+ I currently use a boost converter to bring the single cell voltage of ~3.2V up to 5V for the Pi. If the voltage input range can be either above or below the output voltage, you need a buck-boost converter which tends to be a little more expensive. In general, the highest cost and power efficiency can be had from a buck converter, which converts voltage down. With a useful voltage range of ~2.7V - 3.6V for LiFePO4, two series cells gives a voltage range of 5.4V - 7.2V. We can generate 5V from this with a simple buck converter.
I want the battery stage on any board that uses these packs to be compatible with a pretty wide battery voltage range though so at least 4S LiFePO4 (14.4V max) will also work. - Cell chemistry. My bread and butter is LiFePO4 cells, which give some great reliability and lifetime benefits versus consumer LiPos. But I have also had interest in Lithium Titanate (LTO) for a long time. They are like LiFePO4 on steroids, getting 10K charge/discharge cycles versus LiFePO4's 2K (and LiPo's pathetic 0.3K), and dealing better with cold temperatures. Downsides are lower capacity and lower voltage, with a useful voltage range of ~1.7V - 2.8V.
I may not be making LTO based packs right away, but I want my platform to be compatible with them so I can add them as a super rugged option in the future. The problem is that two series LTO cells only give me 3.4V at the end of discharge. Even at the nominal voltage of 2.4V, two series cells would only make a pack of 4.8V, lower than the 5V output voltage I want. A system using either 2S (2 series) LiFePO4 or 2S LTO cells would have to have a buck-boost to generate 5V.
The other option is to go to three series cells (3S) for LTO. This would give a minimum pack voltage of 5.1V, and I can use a buck converter to get 5V. I think this is the way to go. - Current capability. The whole point of doing a pack is to reduce current at high power, but that doesn't mean that I want it to be wimpy. One great thing about LiFePO4 is its low internal resistance and high current capability. In the #LiFePO4wered/Pi+, the battery output is designed for 4A, in order to be able to still get 2A @ 5V to the Pi when the battery is at 2.7V. So the system is capable of about 10W. I'm reasonably comfortable with 4A, but don't really want to go higher than that. With a 2S LiFePO4 system that is 4A capable, that gives a 20W+ system.
- Physical interface. Or: how do I connect this pack to the board that uses it? There are tons of connector options. Most consumer LiPos use a JST PH connector. RC packs usually have one of these for balanced charging and a separate set of wires and connector for the high current output. With a design current of 4A, JST PH (which is only rated for 2A) wouldn't do. I don't want my packs to have the same connector as most LiPo packs out there anyway since you could pretty much guarantee someone would plug it in to a LiPo charger and ruin the pack.
Still, it needs to be something low cost and readily available to pack manufacturers. In the end, I settled on the JST VH series, which is rated for up to 10A, and allows some headroom for the future.Then there was the question of how many pins. That was a big one.
First of all, even though I'm starting out with 2S LiFePO4, I may do more series cells in the future for systems that need either higher power or higher voltage. And the minimum configuration for LTO would already need three series cells. If you do off-pack balancing like is done with RC packs, you need a different connector depending on the number of series cells. So, was I going to make charge boards that would only be compatible with certain packs? Or have a bunch of different charge connectors on each board to it would be compatible with various packs? The alternative would be to do balancing in the pack, and just bring out the +/-.
Second, there is also the question of what else needs to be connected. For instance, what about an NTC thermistor to measure pack temperature? Or a heater for the pack to be able to charge in low temperature? We could eat up a pin for either. Between balancing, NTC and heater, this connector could become huge.
So I made a decision: since I can't predict what's going to happen exactly, and to keep this as compact as possible, as flexible as possible for the future and as easy to use as possible, I decided to do a 3-pin JST VH connector with +, - and a digital interface to deal with all the rest. - Digital interface. Short of doing something complicated such as modulating a signal onto the power pin, I would need at least 1 pin for communications, so it was easy to settle on a 1-wire interface for this. The goal is to be 1-wire compatible enough on the physical and addressing level to be able to live on the same bus with other 1-wire devices, but beyond that, since Dallas (now Maxim) never defined a "battery pack" device type, I'm doing pretty much what I want beyond that. ;)
The 1-wire interface will be used by the connected board to read out pack ID information, so this will hopefully make the whole system "plug and play". The charger will read the pack ID and know what the pack is, how to charge it, pack limits and features. It will also read out the thermistor(s) and control the pack heater (if available) through the 1-wire interface. The first simple packs will use passive balancing (burn off excess charge as heat) but future ones may have active balancing (redistribute charge between cells) which will also be managed through the 1-wire interface.
This may start to look like a lock-in feature. I hate lock-in, so I intend to make the full protocol publicly available, and the goal is that at least some of my products will also work with individual cells as well. The user in that case will have to configure the charger themselves, while a pack with the interface should be able to configure everything automatically.
