Some links
A project log for H-T-R-C - A Universal Remote With BLE
An open source, hackable, extendable, powerful universal remote with IR, Bluetooth and a low power ARM micro as a base.
jacksonliamjacksonliam • 08/08/2014 at 16:37•0 Comments
I don't really have anywhere else to put this stuff, so in the spirit of this being my living notebook, heres some links I've come across:
A BLE library for the nrf51822 (Arduino?): http://hg.cmason.com/nrf/wiki/Home
Cheap NRF51822 Debugger (McHack) https://www.evernote.com/shard/s13/sh/2557f123-e1fd-4d04-b053-0adac1945c74/6343ffac964a01863d817690f27bbfb5
The Laird BL-600 looks like a pretty good candidate for the module. About 8 quid from mouser and is an NRF51822 with all the trimmings on a certified module. The module can be programmed like any other nrf51822 chip but also contains a stack called smartBASIC which is probably as horrific as the name implies (If you find BASIC horrifc, which I do!).
More info: http://projectgus.com/2014/03/laird-bl600-modules/
Breakout Board: https://github.com/lukeweston/BluetoothModule
The Laird dev kit is £100, so quite an investment. They have a programming Jig which looks like a great idea for bulk programming these modules, but it costs over £300, perhaps I'll need to hack together something like that (fire up SCAD!).
I also remeber reading something about bringing pin20 (or another similar pin) high to turn on the antenna, so better remember that If I use these modules.
Do I need to sign off these logs?
