initial success
A project log for IF sweep from PIC16F18345 NCO
Trying to get a 455kHz sweep signal out of a PIC MCU
bobubobu 03/19/2021 at 02:130 Comments
The project log is written backwards.  After some initial success, the development will be described.  In short, it worked better than expected.
The code was done in MPLAB X.  It's ugly.  I'll clean it up a bit and post it later.
