24 LPM at 92% Concentration Milestone Reached with our Oxikit Project!
Oxikit is a collaboration effort with the help of 200+ volunteers known as the Pillar Tribe made up of Top Engineers, Fortune 100 executives, Chief Medical Directors, Scientists and innovative Entrepreneurs led to a rapid collaboration to bring the OxiKit to life.
KEEP ECONOMY OPEN
‣ 75% hospitalized patients recover with high flow concentrated Oxygen.
‣ Offload 50-75% of demand off the healthcare system
‣ Send concentrators to patients' homes w/ remote Telehealth monitoring
‣ ROX algorithm to predict hours ahead to send critical patients to hospital
‣ Less deaths, catch them early- Less infected healthcare pros
‣ Easy to build designs even 16 year olds can assemble using common and locally found parts
Visit our website to learn more:
https://oxikit.com
Learn how to build your own Oxikit with video tutorials:
https://youtube.com/playlist?list=PL4O1
It's exciting to work on this project, I am adding few remote capabilities to the system to monitor and control certain parameters and introduce some automation into the sytem
It is a diaphragm compressor. They are oil less. It is like a 2 cylinder engine but instead of pistons it has a rubber disc that is used to pump the air. That is also why you don't need oil, because the rubber disc is just pumped up and down instead of moving.
Wow, I didn't expect so much enrichment at such a high flow! What kind of compressor is that? I'd imagine it would need to be oil-less -- perhaps a scroll compressor?
heyaa
