This project is an attempt at making a PCB-Heater that reflows other PCBs! It's works just like a 3d-printer's heat bed and the aim is to reflow low-melting solder paste. For the first test I used the TS391LT50 which has a maximum reflow temperature of 165°C .
As shown in the first test video, there are still a couple issue that I need to tackle.. But the concept works!! In v2 I will tackle all the issues that I found and also try out 'Self-Reflowing PCBs!!!'
