ROSCOE - A New Machine Cognition Paradigm
A new algebraic machine cognition model and a novel machine vision architecture
A new category theoretic machine cognition model has been developed driven by a new and novel machine vision transform which distills the essence of an image into a set of isomorphic relationships based on a canny/hough/Inverse discrete cosine transform.
The inverse DCT is the basis for the JPEG compression. It is reasonable to assume that an transform that allows the human brain to interpret missing data may also be used to provide an algorithmic means to interpret images that is analogous to the brains process.
The transform distills images into 65000 real values that are algebraically related to their category and relative importance. New image data can be progressively matched.
ROSCOE will provide a compact standalone Java based ROS Master node with novel modifications using the new science of Category Theory for sensor fusion and native Java deep store for durability, crash recovery, and cognitive function. There are no specialized parts or custom PCB builds in this project.
The focus of this project is a very low cost robotic platform that provides a test bed for a new model of machine cognition.
A purpose built micro cluster serves as the 'brain' and the BigSack deep K/V store was optimized for cluster operation.
The Robot Operating System Java version, is used as the main control bus.
For the maximum power and lowest cost, BLDC e-bike hubs which can also function as jumbo servos to provide articulating joints of industrial power were used.
The system uses a 24V electronics bus and a 48V propulsion bus with 5 and 12v buck converters to power the RPi's and Parrot ARDrone IMU and ultrasonic board. Unlike most robotics projects this one emphasizes multiple compact SBC processors with a high speed network rather than one massive, expensive, power-hungry boardset .
Using the current sensor bus, ROSCOE can:
Detect rising barometric pressure and verbally warn of storms
Roll through clouds of toxic gas to deliver live video feed
Detect unusual magnetic anomalies and verbally report
Detect seismic shocks and tremors to issue verbal warning
Detect rising temperature gradients and issue notification
Warn you of low battery and optionally attempt recharge
Warn of motor faults
Interface with dozens of advanced sensors with hot pluggable drivers including LIDAR
Warn of impending impact
Detect motion and take action if necessary
Interface to Internet or work standalone. Video and data feed from anywhere in WiFi range
Push a loaded trash bin to the corner, *before* the trash guy gets there
PHYSICAL DIMENSIONS AND SPECIFICATIONS
Length Overall: 24"
Width and Wheel Track: 16"
Height: 32" max.
Weight: Est 60-70 lbs.
Wheel diameter: 16"
Number of Wheels: 3, 2 driven, 1 360 degree passive castor
Top Speed: Est 35-40 MPH
Drive Type: Differential, IMU integrated
Power Bus: 48V/24V
Base OS: Linux/ROS
Microcontrollers: 1 ODriod U3 1 Mega2560
Network: Switch managed IP
Sensors: IMU, 2 cameras (front/rear), 2 forward ultrasonic sensors hi/lo
Est. Cost: ~$1200
Visible:Bosch BNO055 IMU mounted in pill bottle sealed with gorilla tape upper right. 3 Motor drivers left side. Middle top; low voltage dropout and power distro custom board. Front right; camera and ultrasonic nodes. 2 Odroid C2s, master ROS node and computation on one. IMU, camera, wireless AP on the other. 1 Odroid C1, real time motor controller talking to Mega2560 via G-code to custom realtime c++ OO driver module. ROS Java Lite drives the entire system. This is one of 2 robots using radically different propulsion and hardware but the same exact code dropped in except for 1 config file, which is the point of the exercise.
JPEG Image - 1.23 MB - 03/12/2018 at 21:20
Preview
Download
Permobil C400 robot, former surplus mobility chair of Hackerspace entombment. Shown with charger attached in an older configuration. ROS Java Lite drives the entire system. This is one of 2 robots using radically different propulsion and hardware but the same exact code dropped in except for 1 config file, which is the point of the exercise. A remote PS3 controller and first person viewer with 5x7 color screen is used for remote control as the robot contains a wireless N access point. Yes,I got new tires.
JPEG Image - 1.08 MB - 03/12/2018 at 21:18
Preview
Download
  • 1 × 20mm Ammo case
  • 2 × Brushless DC 3 Phase e-bike hubs
  • 1 × Roboteq VBL2360 dual channel controler
  • 3 × RaspberryPi model B
  • 1 × 4 amp USB wall charger for 5V logic
View all 25 components
  • ROSCOEs RosJavaLite powering 24v gear motor surplus wheelchair
    J Groff03/12/2018 at 21:24 0 comments
    Permobil C400 robot, former surplus mobility chair. ROS Java Lite drives the entire system. This is one of 2 robots using radically different propulsion and hardware but the same exact code dropped in except for 1 config file, which is the point of the exercise. A remote PS3 controller and first person viewer with 5x7 color screen is used for remote control as the robot contains a wireless N access point.
    https://www.linkedin.com/feed/update/urn:li:activity:6379061242572738561
  • New Brain: 24v 9 node supercluster in a box
    J Groff12/20/2014 at 20:13 0 comments
  • ROSCOES New Brain: Supercluster in a Shoebox
    J Groff12/11/2014 at 19:47 0 comments
    I'm building my dream machine! Purpose built supercluster in a box matched to BigSack software. Not often as a developer you get to build a machine to match your software. I am using 8 ODroid C1 1.5 gHz quad proc Cortex A5 SBC with 1 gig memory each and gigabit ethernet. Also got 8 16GB eMMC cards, about 3x performance from SD flash. Each of these 8 workers will service one tablespace of every data store. Each database is composed of 8 memory mapped tablespaces. The master will be an ODroid XU3 octocore Cortex A15 with 2 gig running at 2 gigahertz. The master handles the redo log files and multiplexes requests to the worker nodes and gets blocks back. The transport is UDP fixed block size @ 4096 bytes. Each worker node is on its own UDP port. A cluster lives and dies by its switching fabric so I got 2 6 port 24V 1000TX industrial switches, those were the most expensive part, spent about a grand on the computer boards but the switches were $1300 apiece. Had to get 2 Dc/Dc converters from 24V to 5V @ 8A to power the worker nodes, those were $300 a pop. Still I doubt there is any mainframe that can match it pound for kilo when its running. When it is, I can transplant it right into ROSCOE himself. I have accepted the fact that I need a separate 24V bus just to power computing.
    The eMMC is supposed to be 300 MB/sec so thats 2.4 gigabytes per second IO to permanent storage total aggregate.
    8 procs at 1.5 GHz is 12 GHz plus 2 is 14 gigahertz aggregate clock.
    8 cores master + 4 cores each node times 8 nodes is 40 total cluster processor cores
    10 gigabytes total cluster RAM. 8 x 16 GB nodes plus 64GB master is 180GB eMMC total cluster perm storage (without extra flash, eMMC leaves Micro SD flash space open)
    8 gigabit ethernet channels running UDP is total 1 gigabyte per second burst cluster throughput with all worker nodes fully active
    After assembly, I will run my new Canny/Hough/Inverse DCT transform and build the AMI Algebraic Machine Intelligence model based on the exemplars of the Caltech 101. I can then test the Caltech 101 full dataset on the new model. After refinement its on to Caltech 256, PASCAL VOC 2007 and whatever else. If I am cracking the Caltech 256 at 90% with my shoebox robot brain attention will follow.
  • ROSCOE's Oriented Roundel
    J Groff08/31/2014 at 19:07 0 comments
    No, its not a band, yet. The ARDrone has a built-in machine vision capability that recognizes certain key images, one of which is shown below. The data stream responds with the estimated distance, which I believe is derived from the ultrasonic sensor, and the orientation in degrees rotation with the below image being at 90 reported degrees. So ROSCOE has a 'toy' that he get agitated and tries to find if he cant see it within 500 CM, if he can he will sit 500CM away and stare at it. In a way its an extremely sophisticated 'off' switch as we move into more motion studies. The movement algorithm is extremely simple; move forward by issuing 50mm forward motion Twist messages on the ROS 'cmd_vel' topic every 500ms, which is a standard ROS communication pattern. Four or five inches per second indoors for this thing is enough, it will push the furniture out of the way, and not just the end tables either. The ARDrone published sensor data and external ultrasonics are partially fused to avoid shocks/off axis and we include the publication of 'ardrone/vision' Pose2D range/orientation message if a roundel is detected by the ARDrone. The 'cmd_vel' movement publisher subscribes to the 'ardrone/vision' topic and if we see the roundel within 500 cm don't issue movement publication on 'cmd_vel' topic for that 500ms interval. If we are moving and an obstacle or shock is encountered, rotate 30 degrees off axis, or if the ultrasonic readings are below 200mm range bottom sensor or 300mm top sensor, back up 50mm, then continue to process Twist messages from the 'cmd_vel' ROS topic.   The baseline behavior here will allow us to integrate the  functor-based natural transformation cognitive functions now that there is a partial data fusion pipeline of video/accelerometer/gyro/ultrasonic/machine vision/magnetometer.
  • New XmlRpcServer on GitHub
    J Groff08/30/2014 at 03:14 0 comments
    ROSJava takes a special version of XmlRpcServer with bugfixes. I have added to that by replacing ThreadPool with a ThreadPoolManager singleton that uses java.util.concurrent Executors as intended by modern standards. Thread management is much better and I can see a much faster spinup of the Master and Slave servers. There also seem to be less NPE's but I also refactored ROSJava to do better checks on collection members so nulls are accounted for in 'equals' and 'hashCode' methods. Anyway, onward and upward. New link is to the left.
  • Fun with Obstacles
    J Groff08/29/2014 at 01:39 0 comments
    This is the most powerful robot I have encountered. I lost the lower ultrasonic so it kept getting 0 readings making it think something was right on top of it so of course it spins in circles trying to avoid the 0 distance object, duh. I tried to grab it to shut down the controller but even at 1/10 power it cranked me. It will obviously have to learn that 1 360 deg. rotation is sufficient to decide a stop. Due to the kinematics it seems like enough power to move the machine is enough to render it too much for muscular override due to the weight of the thing.
  • Robusst
    J Groff08/19/2014 at 18:41 0 comments
    Bus active for about 36 hours with full nav, video, ultrasonics, etc publishing and subscribing. The unit is positioned such that when someone passes by within range of 300mm it will announce "Excuse me, you are nn millimeters too close to my feet" and/or "Excuse me, you are nn millimeters too close to my head" so its easy to confirm the bus is still operational just by walking by, or if the cat is becoming petrified by walking by the lower ultrasonic and causing it to speak only of its 'feet'. The subscriber is listening to 'range' topics from nodes ardrone and robocore (Parrot and floor level ultrasonics) and doing a simple check which results in the VoxHumana speech module activating or not. Occasionally, an error from the RS232 comms between lower ultrasonic->arduino->core process->ROS allows a zero to creep through so you get "Excuse me, but you are zero millimeters too close to my feet". Passive debugging tools are neato! I did lose the Edamax wireless USB dongle that talks to the ARDrone boards from RPi 1, perhaps from heat. It gradually degraded such that errors from the nav thread were popping up in the form of broken DatagramSockets so I added code to reconnect and tickle the port under those conditions but after replacing the dongle, few broken sockets. Also had to work out all the static persistent routes for bootup.  Serendipitous security was achieved when I moved the master registration server to the second RPi. RPi 1 is not set up to source route packets to RPi 2 so its not possible to connect to the master from outside of RPi 1. Nobody can hijack your 'bot by connecting wirelessly and spinning up a ROS node. About the most that could be done is to issue disconnects from the wireless network or cut off video or sensor data. So we are finally good to go with a stable, open platform and can move on to the really interesting part of this project.
  • 100% Pure Functionality
    J Groff08/17/2014 at 22:32 0 comments
    Replaced xuggler dependencies preventing full implementation on Raspian. Modified h264j to be optimized with ROSARDrone. End-to-end testing on RPi successful. Moved master to roscoe2, second RPi, to distribute load. Performance is acceptable at this point. Added VoxHumana speech module to GitHub.
  • Robot Up
    J Groff08/15/2014 at 23:19 0 comments
    After ensuring that no more localhost bindings were taking place by ensuring the ROS_IP / ROS_HOSTNAME were set the same problem with Connection Refused occurred. Like many problems this one was related to a combination of my own stupidity and a bugs in the system. If ROS encounters a new node registration with the same name as an existing node it will try to replace the slave server, however, it assumes an immediate slave server restart and tries to connect to that as-yet-unstarted server. That is the bug. The stupidity was my accidentally using the same node name as I did for the publisher, causing the situation to begin with. Eventually, after numerous retries and cringe-inducing stack dumps a connection is made to the new server and traffic flows. My initial test case is having ROSCOE listen to range and status and speaking the status message and checking range for values < 100 cm and report that by saying "Excuse me, but you are <nnn> centimeters too close", all of which it now does via the ROS bus on Raspberry Pi!
  • In the End, I Need Only One
    J Groff08/13/2014 at 22:26 0 comments
    So it occurred to me that I really dont need to have all addresses assigned via DHCP and indeed, that would suck. The only one I need is the immediate node attached to the ARDrone to have contact with the outside world and get a DHCP address, everyone else can have a static IP, including the eth0 port on the same node as wlan0 attached to ARDrone. Of course, name resolution and routing are fuXXored  there so it requires manual routing and changes to /etc/network/interfaces as indicated in the amended build instructions.
View all 28 project logs
  • 1
    Step 1
    Software:
    To configure the RPi to connect to the ARDrone boardset edit the following /etc/wpa_supplicant/wpa_supplicant.conf
    ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
    update_config=1
    network={
    ssid="ardrone2_XXXXXX"
    key_mgmt=NONE
    priority=-999
    The /etc/network/interfaces should appear as follows.
    auto lo eth0 wlan0
    iface lo inet loopback
    iface eth0 inet static
    address 192.168.1.252
    netmask 255.255.255.0
    gateway 192.168.1.1
    allow-hotplug wlan0
    iface wlan0 inet manual
    wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
    iface default inet dhcp
    post-up route add -host 192.168.1.1 wlan0
    post-up route add -host 192.168.1.3 wlan0
  • 2
    Step 2
    Software:
    The order ops for building the ROSJava is:
    1) Use ant build.xml on rosjava_bootstrap
    2) proceed to rosjava_messages, build.xml which uses RosBase.jar above
    3) proceed to rosjava and build using RosBase.jar and RosMsgs.jar from above
  • 3
    Step 3
    Software:
    These are the third party libs needed for ROSJava:
    netty-3.2.0.Final.jar
    commons-pool-1.6.jar
    commons-lang-2.6.jar
    ws-commons-util-1.0.1
    commons-httpclient3.1.jar
    en_us.jar
    commons-digester-1.8.1.jar
    xmlrpc-common-3.1.3.jar
    xmlrpc-server.jar
    commons-logging-1.1.2.jar
    commons-io-2.4.jar
    xmlrpc-client-3.1.3.jar
    commons-net-1.4.1.jar
    The result of the execution of all build.xml ant tasks:
    RosBase.jar - org.ros.* implementations (topic,field,messages,namespace)
    RosMsgs.jar - standard messages (see pic)
    RosMsgsGeom.jar - geometry messages
    Ros.jar - ROS core
View all 7 instructions
J Groff wrote 07/31/2014 at 17:47 point
In the 'Wish List' department:
http://www.dfrobot.com/index.php?route=product/product&product_id=1125#.U7u5CPmSwm5
LIDAR! for $398.90! Which still seems like too much! I'll get one when its the same price as Kinect, $129.95 is my price point of choice!
Adam Fabio wrote 07/24/2014 at 03:26 point
Thanks for entering The Hackaday Prize Jonathan! ROSCOE is quite an amazing robot-in-progress! You've definitely done a ton of work just standing up your ROS-java fork. Keep the updates coming in, and don't forget about the video!
