ROSCOEs RosJavaLite powering 24v gear motor surplus wheelchair
A project log for ROSCOE - A Scalable, Platform Independent Robot
A new algebraic machine cognition model and a novel machine vision architecture
j-groffJ Groff 03/12/2018 at 21:240 Comments
Permobil C400 robot, former surplus mobility chair. ROS Java Lite drives the entire system. This is one of 2 robots using radically different propulsion and hardware but the same exact code dropped in except for 1 config file, which is the point of the exercise. A remote PS3 controller and first person viewer with 5x7 color screen is used for remote control as the robot contains a wireless N access point.
https://www.linkedin.com/feed/update/urn:li:activity:6379061242572738561
