Bars and copper
A project log for Ribbon Speaker
Based on JGJMatt's Instructable.
jeremy-gJeremy g. 03/25/2021 at 16:030 Comments
Copper tape and Neodymium bar magnets are here. Just need to print out the core and the horn for test fitting. Also need to order the 2mm diameter copper wire for the guards as well.
Then on to the amplifier design. I am still debating if I should integrate the 6j1 pentode amplifier into the speaker ( would be an interesting look ) or if i should make it its own separate box.
Suggestions?
