I needed some amplifier for my new speakers, so i built one. It's designed as dual-mono - two completely independent amplifiers. Each has its own power supply and DC speaker protection on 4-layer PCB. Output power is 50W/8R with balanced supply voltage of +/- 35V, each amplifier has dedicated winding on power transformer. I've also built a simple stereo loudness control on another PCB.
It's not done yet, I'm currently working on enclosure and mechanics.
Details
You can find original schematics here and here (only in Slovak and Czech language). I'm not the author of these circuit, i just made some modifications.
I 3D printed a simple front and rear panel, top cover and potentiometer knob. Unfortunately, panels are a bit warped but it doesn't look so bad. Heatsinks are mounted on wood board.
