Helpful list of links
A project log for ATTINY_85 Sheild
A shield for working with ATTiny85's
seth-whitingSeth Whiting 04/15/2021 at 19:340 Comments
Making a list of helpful links that I've used while making this project. It's a bit unsorted but wanted to get the info out there.
AVR Tutorial - Software setup for Windows
ATtiny85 timer tutorial: generating time delay using Interrupts - Gadgetronicx
Digispark DIY: the Smallest USB Arduino : 9 Steps (with Pictures) - Instructables
Removing a Curse from ATtiny85 Fuses
>> Little Wire
Engbedded AVR Fuse Calculator
High Voltage programming/Unbricking for Attiny – Arduino, ESP8266, ESP32 & Raspberry Pi stuff
(198) Programming ATtiny85 & flashing a Bootloader (Search Timed Out - FIX) - YouTube
ATtiny85 Powered High Voltage AVR Programmer - Hackster.io
GitHub - RalphBacon/ATTiny85_Fuse_Resetter: Want to use all SIX GPIO pins on the ATTiny85? Now you can.
Arduino/Uno/AVR_High_Voltage_Fuse_Programmer at master · GadgetReboot/Arduino · GitHub
Integrate ArduinoISP and Atmel Studio : 4 Steps - Instructables
