Robots Riding Robots?
04/07/2024 at 23:55 • 0 commentsI've been working in Unity to develop software for my Trike/Torso. This video talks about what I'm doing, and shows some sims in Unity.
4 Axis Robot Arm for Torso/Trike Robot
10/09/2023 at 13:24 • 0 commentsWhile working with a sim in Unity, I felt like the 3 axis arms didn't do everything I wanted. In this video I show a 4 axis arm.
7 Segment Robot Spine
10/09/2023 at 13:22 • 0 commentsI finally got around to making some eyelets with bearings, so I decided to try them out on on 2 experimental segments going up into the rib cage.
Humanoid Quad - Leg Update
06/16/2023 at 18:16 • 0 comments -
Robot Torso Updates
05/03/2023 at 19:24 • 0 commentsXometry sent me some cool pieces this week. I talk about those. Then I close things with some cool shots of the torso.
X Axis Anchor Update
04/24/2023 at 23:45 • 0 commentsRecently got some X Axis anchors figured out on my bot. Check out the progess.
Gaming Robot Status
03/17/2023 at 19:27 • 0 commentsAs I recently learned how to build a balancing robot, it seemed only fitting to update this robot.
Humanoid Quadruped - Rib Cage Update
08/18/2022 at 01:46 • 0 commentsI like how the rib cage is looking, but I wanted to improve how the lower rib cage looked. In this video I show the polycarbonate pieces I put in for the lowest 4 ribs.
Humanoid Quad Update
06/02/2022 at 16:27 • 0 commentsThe legs on my quad are a shot in the dark. In this video I explain what I'm trying to get. I also show some updates.
Humanoid Quadruped Leg Joints
05/17/2022 at 15:01 • 0 comments
