PnPPP - Pick & Place Pre-Processor
A tool to rotate parts in PNP files to match fab orientation, panelize PNP and BOM data, reformat CSV & more
Public Chat
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
PnPPP is a tool for automatically converting PCB assembly files to the format required by your fab or machine, automatically rotate parts to the correct orientation and duplicate pick-and-place data with new positions for the purpose of panelization. All required meta data can be maintained directly within the CAD project.
- Parse and re-generate BOM and PNP files
- Continuously scan filesystem for changes and automatically process changed files
- Rotate parts in PNP file based on per-component setting in the CAD tool
- Duplicate PNP data with adjusted coordinates to generate PCB panels from a single board
- Rename, re-order and delete columns
- All meta data (for auto-rotation, panelization etc.) can be managed from within the CAD project
Free, Open Source, GPL. See github page for more info
