Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Tutorials Events Hackerspaces Profiles Hackaday.com Tindie Marketplace
Sign up Log in
High Voltage Regulated Power Supply
Geiger–Müller Tubes and Photomultipliers Tubes operate at voltages between 300v to 900v but also need to be regulated and low noise,
Robert HartRobert Hart
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.6k views
2 comments
45 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 2
View Gallery
1.6k
2
45
7
Team (1)
  • Robert HartRobert Hart
Join this project's team
completed project
This project was created on 07/06/2014 and last updated 7 years ago.
Description
I've built a few different power supplies for Geiger–Müller Tubes and Photomultipliers Tubes and this one has been the most reliable. http://www.hardhack.org.au/hv_reg_power
The circuit is based around a cheap CCFL inverter module and the common LM2576 3 Amp Adjustable Switchmode Regulator which can be bought over the counter at many electronics stores. The output of the inverter is rectified and filtered and and then feed back into the feedback of pin 4 on the LM2576 through a voltage divider. The output of the LM2576 is then used to supply of the inverter.
The LM2576 maybe seem like over-kill but my aim is to be both accessible and cost effective, and although there are better chips available unless your building a few hundred of these, it would be harder to choose a cheaper and more accessible alternative.
Details
Log In/Sign up to comment
Sign up with Github
OR
Robert Hart wrote 09/22/2015 at 21:20 • point
Hi HC I've used this design for over 10 years on many project, most were built from junk box parts on vero board, it's low noise and quite stable. Its to power high impedance loads such as Geiger, proportional or photomultiplier tubes  e.g. #Cosmic Ray (Muon) 81 (9x9) Pixel Hodoscope.  No doubt it could be improved, please feel free to redesign it as well as my other projects are open source and build for recreation, not production.  More details are on my website http://www.hardhack.org.au/hv_reg_power
K.C. Lee wrote 09/22/2015 at 12:51 • point
For high voltage caps in series, the usual advice is to have them connect across voltage balancing resistors.  Some people advice the same for rectifiers too.  Also note that regular resistors not rated for high voltages can have non-linearity.
Build a 0.7-17v linear power supply out of old mobile phone charger (50/60Hz transformer)
Project Owner Contributor
0.7-17V linear power supply from phone charger
podmanicky.michalpodmanicky.michal
The 2017 Hackaday Prize
Small form factor 2 x 7W Hi-Fi stereo amplifier, built from discrete parts
Mini Hi-Fi Power Amplifier
SzoftveresSzoftveres
Nice amplifier
80W HiFi Audio Amplifer
PeroPero
TDA7294 amplifier can operate at 80 V voltage supply delivering an output current of ±10 A due to it monolithic characteristic.
TDA7294 operational amplifier, Utsource
Electroniclovers123Electroniclovers123
Going up?
© 2023 Hackaday
Yes, delete it Cancel
You are about to report the project "High Voltage Regulated Power Supply", please tell us the reason.
Send message
Remove Member
