Clap Switch Circuit Using 555 Timer
We will use two basic clap switch circuit diagrams i.e. (With IC 555 Timers and without 555 Timer).
Public Chat
Clap Switch is a basic electronics mini-project, made with the help of the basic components. Clap Switch has the ability to turn ON/OFF any electrical component or circuit by the clap sound. We will use two basic clap switch circuit diagrams i.e. (With IC 555 Timers and without 555 Timer).
It is known as Clap Switch because the condenser mic which will be used in this project will have an ability to take the sound having the same pitch as the clap sound as the input. Although it doesn’t mean that the sound will have to be exactlt the clap sound, it can be any sound having the same high pitch as clapping sound. We can also say that it converts the sound energy into the electrical energy because we are giving an input to the circuit as a sound whereas the circuit gives us the output as an LED light when glows (electrical energy). In more simple words, the circuit is able to convert the sound energy to activate the circuit and led provide electrical energy as an output in the form
JPEG Image - 93.11 kB - 04/03/2021 at 09:13
Preview
Download
document - 126.58 kB - 04/03/2021 at 09:12
Download
