Added a Disassembler
A project log for 2:5 Scale KENBAK-1 Personal Computer Reproduction
Make a working reproduction of the venerable KENBAK-1 with a fully integrated development environment including an Assembler and Debugger.
michael-gardiMichael Gardi 07/15/2021 at 20:090 Comments
I can't seem to stop wanting to improve my KENBAK-2/5 project, and anything that gets me "into the weeds" of the instruction set is especially appealing. To that end I have created a stand alone command line Disassembler. I have added the Python script to my GitHub repository and created a release.
Here is the online help:
usage: Disassemble a binary or delimited text file to KENBAK-1 source
       [-h] [-s] [-d] [-a] -f FILE
optional arguments:
  -h, --help            show this help message and exit
  -s, --save            save the disassembly to a .asm file
  -d, --dump            dump the disassembly to standard out
  -a, --address         add the instruction address to each line
  -f FILE, --file FILE  file to disassemble
Writing a disassembler is an interesting exercise, one that I had never undertaken before. Faced with an array of 256 raw bytes and trying to coax some meaningful structure out of it was pretty daunting.
The first thing I did was to determine which of the bytes represented the program code vs program data. Fortunately the first byte of code can be ascertained by looking at the fourth byte in memory which holds the PC (program counter/instruction pointer - defaults to 4). From that point, consecutive instructions can be readily resolved, that is until a "jump" instruction is encountered. By carefully following all of the jumps to other blocks of code you can create a map of all the code in the program.
All of the non-code bytes are then assumed to be data. But which of those bytes represent constants vs data bytes that will be manipulated by the program.  Since all of the "registers" on a KENBAK-1  (A, B, X, PC, OUTPUT, AOC, BOC, XOC, and INPUT) are at fixed positions in memory that is a good place to start marking them as data bytes using a DB directive. The other bytes that will be written to can be determined by looking at all of the instructions that store to memory: STORE, SET, and JMK.  Everything else is then treated as a constant.
Finally I did a pass to convert all of the memory references in the code to labels to make reading the emitted code a bit easier.
To test the disassembler I input the 256 byte "Day of the Week.bin" file created by the IDE assembler and compared the assembly output to the original code that I wrote.  Furthermore I ran the disassembled code inside of the IDE to ensure that it indeed worked as expected.
Here is the original code:
; Program to calculate the day of the week for any date. To start this program you will
; have to input the date in four parts: Century, Year, Month, and Day. Each of the parts
; is entered as a two digit Binary Coded Decimal number (ie. the first digit will occupy
; bits 7-4 as a binary number, and the second digit bits 3-0) using the front panel data
; buttons. The steps to run this program are:
; 1) Set the PC register (at address 3) to 4.
; 2) Clear the input data then enter the date Century.
; 3) Press Start.
; 4) Clear the input data then enter the date Year.
; 5) Press Start.
; 6) Clear the input data then enter the date Month.
; 7) Press Start.
; 8) Clear the input data then enter the date Day.
; 9) Press Start.
; The day of the week will be returned via the data lamps using the following encoding:
;      7-Sunday 6-Monday 5-Tuesday 4-Wednesday 3-Thursday 2-Friday 1-Saturday
; All lamps turned on means the last item entered was invalid and you have to restart.
; Get the date we want the day for.
    load    A,INPUT         ; Get the century.
    jmk 	   bcd2bin
    store   A,century
    halt
    load    A,INPUT         ; Get the year.
    jmk     bcd2bin
    store   A,year
    halt
    load    A,INPUT         ; Get the month.
    jmk     bcd2bin
    sub     A,1			    ; Convert from 1 based to 0 based.
    store   A,month
    halt
    load    A,INPUT         ; Get the day.
    jmk     bcd2bin
    store   A,day
    load    A,0b10000000    ; Setup the rotation pattern.
    store   A,rotate
; All the inputs should be in place. Start the conversion.
    load    A,year          ; Get the year.
    sft 	   A,R,2           ; Divide by 4.
    store   A,B             ; Save to B the working result.
    add     B,day           ; Add the day of the month.
    load    X,month         ; Use X as index into the month keys.
    add     B,monkeys+X     ; Add the month key.
    jmk     leapyr          ; Returns a leap year offset in A if applicable.
    jmk     working         ; Working...
    sub     B,A             ; Subtract the leap year offset.
    jmk     cencode         ; Returns a century code in A if applicable.
    add     B,A             ; Add the century code.
    add     B,Year          ; Add the year input to the working result.
chkrem
    load    A,B             ; Find the remainder when B is divided by 7.
    and     A,0b11111000    ; Is B > 7?
    jmp     A,EQ,isseven    ; No then B is 7 or less.
    sub     B,7             ; Yes then reduce B by 7.
    jmp     chkrem          ; Check again for remainder.
isseven
    load    A,B             ; Is B = 7?
    sub     A,7             ; Subtract 7 from B value.
    jmp     A,LT,gotday     ; No B is less than 7.
    load    B,0             ; Set B to zero because evenly divisible.
gotday
    load    X,B             ; B holds the resulting day number. Use as index.
    load    A,sat+X         ; Convert to a day lamp.
    store   A,OUTPUT
    halt
error
    load    A,0xff          ; Exit with error
    store   A,OUTPUT        ; All lamps lit.
    halt
; Store inputs.
century db
year    db
month   db
day     db
; Static table to hold month keys.
monkeys 1
        4
        4
        0
        2
        5
        0
        3
        6
        1
        4
        6
; Need to preserve A while performing some steps.
saveA   db
; Subroutine to blink the lamps to indicate working.
rotate  db                  ; Pattern to rotate.
working db                  ; Save space for return adderess.
    store   A,saveA         ; Remember the value in A.
    load    A,rotate        ; Get the rotate pattern.
    store   A,OUTPUT        ; Show the rotated pattern.
    rot     A,R,1           ; Rotate the pattern.
    store   A,rotate        ; Save the new rotation.
    load    A,saveA         ; Restore the value of A.
    jmp     (working)       ; Return to caller.
    org 133                 ; Skip over registers.
; Subroutine takes a BCD nuber in A as input and returns the equivalent binary number
; also in A.
bcd2bin db                  ; Save space for return address.
    store   A,X             ; Save A.
    sft     A,R,4           ; Get the 10's digit.
    jmk     chkdig          ; Make sure digit is 0 - 9.
    store   A,B             ; B will hold the 10's digit x 10 result
    add     B,B             ; B now X 2
    sft     A,L,3           ; A is now 10's digit X 8
    add     B,A             ; B now 10's digit X 10
    store   X,A             ; Retrieve original value of A
    and     A,0b00001111    ; Get the 1's digit value in binary.
    add     A,B             ; Add the 10's digit value in binary.
    jmp     (bcd2bin)       ; A now has the converted BCD value.
; Subroutine determines if the date is a leap year in January or February and returns
; an offset of 1 if it is, and 0 otherwise.
leapyr  db                  ; Save space for return address.
    load    A,month         ; Check to see if month is January or February.
    and     A,0b11111110    ; Are any bits other than bit 0 set?
    jmp     A,NE,notlpyr    ; Yes then not January or February. Return 0.
    load    A,year          ; Is this an even century?
    jmp     A,NE,chkyear    ; No then have to check the year.
    load    A,century       ; Yes so see if century evenly divisible by 4.
    and     A,0b00000011    ; Are bits 1 or 0 set?
    jmp     A,EQ,islpyr     ; Yes evenly divisible by 4 and is a leap year.
    jmp     notlpyr         ; No this is not a leap year.
chkyear
    load    A,year          ; See if rear evenly divisible by 4.
    jmp     A,NE,notlpyr    ; Yes so not evenly divisible by 4 and not a leap year.
islpyr
    load    A,1             ; Offset 1.
    jmp (leapyr)            ; Return offset.
notlpyr
    load    A,0             ; Offset 0.
; Subroutine determines if a century code needs to be applied to the calculation.
cencode db                  ; Save space for return address.
    load    A,century       ; Century must be between 17 - 20.
chkmin
    sub     A,17            ; Is century less than 17?
    jmp     A,GE,chkmax     ; Yes so century >= 17. Check max boundry.
    load    A,century       ; Increase century by 4.
    add     A,4
    store   A,century
    jmp     chkmin
chkmax
    sub     A,20            ; Is century greater than 20?
    jmp     A,LT,retcode    ; No so calculate century code.
    jmp     A,EQ,retcode
    load    A,century       ; Decrease century by 4.
    sub     A,4
    store   A,century
    jmp     chkmax+2
retcode
    load    X,century       ; Calculate the century code
    sub     X,17            ; Create an index into the century codes.
    load    A,ctcodes+X     ; Get the appropriate century code.
    jmp     (cencode)       ; Return century code.
; Subroutine that checks if the digit passed in A is in range 0 - 9.
chkdig  db                  ; Save space for return adderess.
    store   A,saveA         ; Remember value in A.
    load    A,9
    sub     A,saveA         ; Subtract value passed from 9.
    and     A,0b10000000    ; Is negative bit set?
    jmp     A,NE,error      ; Yes so value in A not in range 0 - 9.
    load    A,saveA         ; No so A value in range.
    jmp    (chkdig)         ; Return to caller.
; Static table to hold the output pattern for the day of the week.
sat     0b00000010
sun     0b10000000
mon     0b01000000
tues    0b00100000
wed     0b00010000
thur    0b00001000
fri     0b00000100
; Static table to hold century codes.
ctcodes 4
        2
        0
        6
 And here is the disassembled code:
; Disassembly for [Day of the Week.bin]
          org     0
A         db
B         db
X         db
PC        db
          load    A,INPUT
          jmk     LAB133
          store   A,LAB094
          halt
          load    A,INPUT
          jmk     LAB133
          store   A,LAB095
          halt
          load    A,INPUT
          jmk     LAB133
          sub     A,1
          store   A,LAB096
          halt
          load    A,INPUT
          jmk     LAB133
          store   A,LAB097
          load    A,128
          store   A,LAB111
          load    A,LAB095
          sft     A,R,2
          store   A,B
          add     B,LAB097
          load    X,LAB096
          add     B,LAB098+X
          jmk     LAB156
          jmk     LAB112
          sub     B,A
          jmk     LAB189
          jmk     LAB112
          add     B,A
          add     B,LAB095
LAB062    load    A,B
          and     A,248
          jmp     A,EQ,LAB074
          sub     B,7
          jmk     LAB112
          jmp     LAB062
LAB074    load    A,B
          sub     A,7
          jmp     A,LT,LAB082
          load    B,0
LAB082    load    X,B
          load    A,LAB243+X
          store   A,OUTPUT
          halt
LAB089    load    A,255
          store   A,OUTPUT
          halt
LAB094    db
LAB095    db
LAB096    db
LAB097    db
LAB098    1
          4
          4
          0
          2
          5
          0
          3
          6
          1
          4
          6
LAB110    db
LAB111    db
LAB112    db
          store   A,LAB110
          load    A,LAB111
          store   A,OUTPUT
          rot     A,R,1
          store   A,LAB111
          load    A,LAB110
          jmp     (LAB112)
          0
          0
OUTPUT    db
OCA       db
OCB       db
OCX       db
          0
LAB133    db
          store   A,X
          sft     A,R,4
          jmk     LAB228
          store   A,B
          add     B,B
          sft     A,L,3
          add     B,A
          store   X,A
          and     A,15
          jmk     LAB228
          add     A,B
          jmp     (LAB133)
LAB156    db
          load    A,LAB096
          and     A,254
          jmp     A,NE,LAB185
          load    A,LAB095
          jmp     A,NE,LAB175
          load    A,LAB094
          and     A,3
          jmp     A,EQ,LAB181
          jmp     LAB185
LAB175    load    A,LAB095
          and     A,3
          jmp     A,NE,LAB185
LAB181    load    A,1
          jmp     (LAB156)
LAB185    load    A,0
          jmp     (LAB156)
LAB189    db
          load    A,LAB094
LAB192    sub     A,17
          jmp     A,GE,LAB204
          load    A,LAB094
          add     A,4
          store   A,LAB094
          jmp     LAB192
LAB204    load    A,LAB094
LAB206    sub     A,20
          jmp     A,LT,LAB220
          jmp     A,EQ,LAB220
          load    A,LAB094
          sub     A,4
          store   A,LAB094
          jmp     LAB206
LAB220    load    X,LAB094
          sub     X,17
          load    A,LAB250+X
          jmp     (LAB189)
LAB228    db
          store   A,LAB110
          load    A,9
          sub     A,LAB110
          and     A,128
          jmp     A,NE,LAB089
          load    A,LAB110
          jmp     (LAB228)
LAB243    2
          128
          64
          32
          16
          8
          4
LAB250    4
          2
          0
          6
          0
INPUT     db
 As mentioned the disassembler will accept 256 byte raw binary files as input (files with a .bin extension). It can also parse delimited text files (with a .txt extension). The delimiters can be any combination of  white space characters (like spaces, tabs, newlines, etc.) plus periods, commas, colons, and semi-colons.  The bytes themselves can be expressed as hexidecimal (starts with 0x), decimal (start with 1-9), octal (starts with 0), or binary (starts with 0b) , but must resolve to a number less than 256.
If the --save option is chosen a disassembly file will be generated. The file name will be the same as the input's with the extension replaced by ".asm".
