• Detection Log
    jeff04/06/2021 at 17:04 0 comments
    I have analyzed and graphed the collected data logs.  The data covers everything within a 300 electron-Watt radius of the device.
    there were no aliens detected.
  • Calibrated
    jeff04/06/2021 at 16:22 1 comment
    device correctly reads 0V when only humans are within the detector field.
  • 6 + 6j spurving vanes
    jeff04/06/2021 at 16:20 0 comments
    12 spurving vanes: 6 real, 6 imaginary (not visible in the photos)
  • Drake Feynman
    jeff04/06/2021 at 16:19 0 comments
    This is a fairly simple and straightforward implmentation of a Drake-Feynman Alien Detector.
    wikipedia has most of the details:
    https://en.wikipedia.org/wiki/Drake_equation
  • A small Herring
    jeff04/06/2021 at 16:18 0 comments
    After interference by the neighbor's cat, the herring needs to be replaced.
    Going to try placing it within a sealed vessel below the panatronic fan this time
  • ebay find!
    I found a surplus 17 pantagauss feynman spaculume on ebay. This should allow a detection range of nearly 237 Hertz-meters.
