Here is how it finally looks like
Things used in this project
Hardware components
SOFTWARE COMPONENTS
Hand tools
Story
Hey guys! I hope you already enjoyed my previous projects and you are ready for a new one,
as usual, I made this tutorial to guide you step by step while making this kind of super amazing low-cost electronic project which is the "Arduino Voice Controlled Boat".
During the making of this project, we tried to make sure that this instructable will be the best guide for you in order to help you if you want to make your own Voice controlled robot car or boat,
 So we hope that this instructable contains the needed documents.
This project is so handy to make especially after getting the customized PCB that we’ve ordered from JLCPCB to improve the appearance of our machine and also there are enough documents and diagrams in this guide to allow you to create your Bluetooth Robot Car easily.
We've made this project in just 3 days only, just 2 days to get all the needed parts and next 1 days to finish the hardware making and the assemble.
Before starting let’s see first What you will learn from this instructable:
How Arduino Voice Controlled Boat Works?
As we have already mentioned that this is an Arduino-based project, so Arduino is working here as the brain of the robot. Everything we command to move the Boat will be processed by the Arduino Microcontroller. We have to write a suitable code that will help the Arduino to process and follow our instructions.
Next, we want to send our voice command wirelessly. So here we have decided to use HC-05 Bluetooth Module which is compatible with Arduino & our Android Phone.
In the next step, we have to install an Android App and have to connect our phone with the boat via Bluetooth. Now we will send the voice command using the android app to move the boat as we wish.
Here we have added Five voice commands for Five different instructions. They are
Move Forward – The Boat will move in the forward direction for 2 second
Move Backward – The boat will move in a backward direction for 2 second
Turn Right – The boat will make a 90  ̊rotation on its right side
Turn Left – The boat will make a 90  ̊ rotation on its left side
Run – The boat starts moving in a forwarding direction for a long time
Schematics of the Voice Control Boat/Car  with L293D:
STEP 1
In this step, I have made the Robot Body using PVC Pipe & PVC Boards. I have also attached the motors with the Chassis and have soldered them with some wires.
Here is how it looks like
Then I have attached the propellers with the chassis and here is how it looks like
Now we will make the front side of the boat. We will connect one BO motor with the boat to turn it in left and right direction. But you can connect 2 motor there in the front side if you face trouble by making using one motor.
STEP 2
I have made a PCB file to make it easy to assemble and ordered my PCB from JLCPCB. They are very professional in PCB making and the build time was short. I received my item within 7 working days.
After getting the PCB it was just a less than 2 minutes job to assemble all the components in a proper way.
STEP 3
Now I had to upload the code to the Arduino UNO.So I have attached the USB cable that comes with the Arduino UNO board and follows the steps mentioned below
***Please don’t forget to remove/detach the HC-05 Bluetooth Module before uploading the code. Connect it after the code has been uploaded successfully.
STEP 4
 Here in this step, I have attached the PCB board with the robot body / Chassis and connected the motor terminal with the output terminal of the L293D Motor Driver. I have also attached the 18650 Li-ion battery holder with the chassis and connected the output wires of the battery holder with the input power terminal of the L293D motor driver.
STEP 5
Here in this step, I have attached the 18650 li-ion batteries with the battery holder and finally the motor turns on.
STEP 6
Now you will need the “AMR_Voice” app for controlling the Boat. I have given the Application link in the code you can directly download from there and install it to your Android device.
About  JLCPCB
JLCPCB (Shenzhen JIALICHUANG Electronic Technology Development Co., Ltd.), is the largest PCB prototype enterprise in China and a high-tech manufacturer specializing
in quick PCB prototype and small-batch PCB production. With over 10 years of experience in PCB manufacturing, JLCPCB has more than 200, 000 customers at home and abroad,
with over 8, 000 online orders of PCB prototyping and small quantity PCB production per day. The annual production capacity is 200, 000 sq.m. for various 1-layer,
2-layer or multi-layer PCBs. JLCPCB is a professional PCB manufacturer featured of large scale, well equipment, strict management, and superior quality.
Troubleshoot:
2.    The motor is not rotating in the right direction: If you face this issue then you don’t need to modify any code. You just have to Interchange the motor wires. In a simple way, I can say just connect the Motor to the Motor driver
