Almost all components are now stuffed into the case. Still looks awful but works great.
Cooling and PWM control are working fine.
Next steps: cleaner wiring, making use of the switch and screwing banana plugs for power in and replacing the old power socket with the volt/amp meter.
I would also be interested in checking out the reflector kit as I got mine too hot trying to cut it and ended up scorching it.
