PWM working
A project log for Portable 100W led flashlight
A monster flashlight containing a 100W 8500Lm led with big heatsinks and batteries. With morse function to tell the night goodbye.
yannick-gigawipfYannick (Gigawipf) 07/08/2014 at 16:241 Comment
Almost all components are now stuffed into the case. Still looks awful but works great.
Cooling and PWM control are working fine.
Next steps: cleaner wiring, making use of the switch and screwing banana plugs for power in and replacing the old power socket with the volt/amp meter.
Rawliquid wrote 07/22/2014 at 07:49 point
I don't suppose you would elaborate some on how you connected the pwm control? I have a couple of these sitting around waiting for me to figure that out...
I would also be interested in checking out the reflector kit as I got mine too hot trying to cut it and ended up scorching it.
