Prototype 2
A project log for GLASSES
Custom HUD Smartglasses, made by OmegaVoid
OmegaRogueOmegaRogue 04/18/2021 at 13:450 Comments
Prototype 2 improved on Prototype 1 by decreasing the screen angle from 45° to 22.5°. I had some initial problems with getting the Optics to work correctly, but with a 1.5x lens it worked fine with only minor image warp.
No lens, longer distance from screen
No lens, short distance from screen
2.5x lens, long distance from screen
2.5x lens, short distance from screen
1.5x lens, long distance from screen
1.5x lens, short distance from screen
The next steps for the Hardware are to reduce the weight of Project GLASSES, correct the remaining image distortions by switching to a fresnel lens and putting it at an angle, making a frame to wear it and use it, and mounting an MPU9250 to make things like a virtual horizon possible.
