Connector removal
A project log for MC6205/MS6205 | ESP32 Weatherstation, NTP Clock
Weatherstation based on MC6205 (MS6205) russian gas discharge (Plasma) display using ESP32
jrg-postertjörg postert 05/09/2021 at 07:510 Comments
If you are planning to use the all-internal version, here is the „how-to-not-to-do“ way to remove the connector. ;)
If you don‘t want to preserve it, then it is a way...
