github
05/16/2021 at 22:46 • 0 commentsPublished the sourcecode on github.
https://github.com/jopo64/MC6205 -
Connector removal
05/09/2021 at 07:51 • 0 commentsIf you are planning to use the all-internal version, here is the „how-to-not-to-do“ way to remove the connector. ;)
If you don‘t want to preserve it, then it is a way...
Easteregg
05/08/2021 at 20:41 • 1 commentThere is a hidden set of characters in the original PROM. It was pretty funny to discover it.
Height reduction
05/08/2021 at 20:30 • 0 commentsBe carefull, if you reduce the spacer of the display board to the tube board. Attention not to break the glass-seal.
Testsoftware
05/07/2021 at 21:59 • 0 commentsFirst publish of testsoftware for the MC6205 on Arduino.
The Zip is in the files section. -
MC6205 boxed
05/07/2021 at 17:44 • 0 commentsJust a short update:
A new set of PCB's V1.1-H arrived. This time I had included all parts in the original metallcase.
PCB (Eagle format) and Gerber attached in files section.
Have fun.I'm very satisfied with that look.
PCB's V1.1
04/27/2021 at 08:35 • 0 commentsThe PCB's (V1.1-V) arrived. I've assembled it and it is working flawless.
Driver PCB version 1.1-V
04/13/2021 at 20:36 • 0 commentsCreated new version of the PCB for connecting the ESP32 to the MC6205
Schematics and Gerber attached in the files section.This PCB can be self-etched (traces are pretty wide) and yes, it's double sided.
I've ordered a small batch (5).
