Fixed Sampling Arduino program
A project log for BioAmp EXG Pill v1.0b
BioPotential amplification on your finger tip!
deepak-khatriDeepak Khatri 05/01/2021 at 13:020 Comments
Different BioPotential signals (ECG, EMG, EOG, and EEG) contain information in different frequency bands and require a minimum sampling rate to not lose any valuable data.
FixedSampling Arduino code allows you to set a fixed sampling rate for your Arduino-compatible board's ADC input. Fixed sampling also helps in applying digital filters onto the signal recorded as you are required to have a fixed sampling rate for that.
