PEAC seen as a collection of 2-tap LFSRs
A project log for PEAC Pisano with End-Around Carry algorithm
Add X to Y and Y to X, says the song. And carry on.
Yann Guidon / YGDESYann Guidon / YGDES 08/07/2021 at 21:410 Comments
From the beginning, the link between LFSRs and PEAC was clear, if only the right perspective was used.
So I made an emulation with CircuitJS to make it obvious:
The w4 configuration has a pair of orbits with 135 steps, which don't fit in the screen.
Each level is made of 2 DFF and one full-adder, just like a 2-tap Fibonacci LFSR with a more complex feedback circuit:
One possible application is as a serial-line scrambling circuit (think Ethernet, USB and other asynchronous links), since it can't "get stuck" like a LFSR.
