New packing at work
A project log for PEAC Pisano with End-Around Carry algorithm
Add X to Y and Y to X, says the song. And carry on.
yann-guidon-ygdesYann Guidon / YGDES 12/14/2021 at 04:480 Comments
It was easy to implement the "MIDI/UTF8"-like packing system (see p7ck.c) and I had no problem integrating it with the scanner. The files are quite large (at a fixed 26 bytes per entry) but compress slightly better than decimal-based representations and each output byte takes only a few instructions for import and export. It's fast, the code is compact and it's efficient. And as the update below shows, sort deals well with it.
I already have a script that spreads computations over parallel programs and it's quite convenient for the widths between 16 to 23. I could get a 12× speedup on the i7-10750H with no effort though I should use the pthread library instead of independent programs for convenience: if I want to stop scanning, I must kill all the scanners one by one, or invoke killall...
There is no resumption feature yet but the scan program can start and end at any point. You can find the latest code at parscan01.tgz and it's still missing some features, which I integrate one by one.
____________________________________________
Update: sort works !
It's as simple as this:
LC_ALL=C sort -z -k 1.6,1.10 log10.0.p7k | od -An -v -w26 -t x1
The od command is only to display the bytes. I should write a proper program for this...
I use "only" 3 options/tricks to coerce sort to behave as I want:
Et voilà ! C'est réglé !
The next steps:
tbc...
