Progress
A project log for PEAC Pisano with End-Around Carry algorithm
Add X to Y and Y to X, says the song. And carry on.
yann-guidon-ygdesYann Guidon / YGDES 04/17/2021 at 01:040 Comments
As shown in the previous log A promising 32-bit checksum, I have come up with a nice opcode sequence that fits great with a 80(2)86:
; Checksumming 4 bytes in 6 opcodes
; X=BX, Y=DX
lodsw ax
addc dx, bx
xor bx, ax
lodsw ax
addc bx, dx
xor dx, ax
The magic is with the opcode LODSW that both loads a value from DS:SI into AX, and increments SI. It could be coded otherwise with fewer opcodes but still contains as many actual operations:
; X=BX, Y=DX
addc dx, bx
xor bx, [di]
addc bx, dx
xor dx, [di+2]
; and here you have to deal with
; manually incrementing DI etc.
The rest is some basic dataflow graph hacking, as shown below :
The question is open whether this is still valid for 32 bits registers or 64 bits. I know it's not working for 8 bits and I'll have to research... If needed.
So far, it's a nice little hash that fits the bill for small datagrams, with very little init to do, only one temp register, the X and Y can be merged (XOR) to give a 16-bits checksum, or just left as is and concatenated to provide 32 bits.
Working with carry is possible with x86 or POWER processors, but painful with Alpha/MIPS/SPARC/RISCV style RISC cores.
OTOH this updated structure makes the digital circuit even smaller and easier !
But as noted before : I only aim at minimalism and efficiency, that is : the best detection and speed per gate or instruction. If one bit toggles at the input, I only care that it toggles at least one output bit. And this is already a win: so far, this checksum surpasses ADLER32 and Fletcher, without requiring more resources, and it is almost as good as CRC32 without the hassles.
