Just another hypothesis.
A project log for PEAC Pisano with End-Around Carry algorithm
Add X to Y and Y to X, says the song. And carry on.
yann-guidon-ygdesYann Guidon / YGDES 04/12/2022 at 22:150 Comments
In a previous log (More questions on gPEAC) I evoked a hunch I had but nothing was explained. I write this log to close this gap.
I suspect a mechanism that is somewhat similar to what I have seen with prime numbers, since I have studied algorithms (reverse sieves) to generate them. The common hints are
From there it is possible to imagine a similar algorithm to detect which moduli are not going to give a perfect orbit.
I should try the sieve with other prime numbers, as already suggested in another log.
