Firmware ported to VIAL branch of QMK
07/27/2024 at 02:50 • 0 commentsPorted firmware to VIAL branch of QMK, which has a GUI configurator.
Had to first port it to actual QMK source since I originally had just used kbfirmware which is no longer maintained. Then port that to VIAL.
Here's a screenshot of the configurator.
internals and the current key layers.
04/11/2021 at 06:06 • 0 commentsjust wanted to make post including some of the pictures as well as the current key layout.
Here's the wiring.
This is the pro micro and wiring as well as the hardware reset switch I wired in.
and then screenshots from kbfirmware.com of the current state of the key layers.
layer 0
layer 1
layer 2
layer 5
Ticktok
