Version update coming: new project
A project log for 10mbps over 1km on a single pair of wires
A simple 50mmx44mm module to route power and differential signals (RS-485) over RJ-45
Alexander WilliamsAlexander Williams 06/30/2022 at 23:410 Comments
I've designed and built a new model of this board, except it's a bit different and has a completely different layout and PCB board size.
For that reason, I'll be publishing it under a new project, and the best part is it works perfectly with this board.
This board will also receive a revision (v.04) with more SMD components.
More details in August, as I wait for, and test the first prototype.
Stay tuned...
PS: Here's a hint - μHAT ;)
