Initial tests with v.03: success!!
A project log for 10mbps over 1km on a single pair of wires
A simple 46mmx22.5mm module to route power and differential signals (RS-485) over RJ-45
alexander-williamsAlexander Williams 05/18/2021 at 05:300 Comments
I soldered the components onto two v.03 modules and ran some initial tests with a string of 5V LEDs, so far the modules work perfectly!
"Off" mode, set through the DIP switches also works as designed.
I'll continue some load and noise tests, and post another update once that's done.
