Yay, v.02 boards have arrived
A project log for 10mbps over 1km on a single pair of wires
A simple 46mmx22.5mm module to route power and differential signals (RS-485) over RJ-45
alexander-williamsAlexander Williams 04/29/2021 at 04:240 Comments
The v.02 boards arrived today and they look sooo much better than v.01. Although this board is a through-hole only version, it should be 100% functional.
I'm going to solder the components and make 2 modules, run some tests, and then make another post with my results.
Hopefully I can order the v.03 module before the weekend.
