Onboard Programmers are great
On microcontroller development boards (such as ST Nucleo Boards) it's very handy to have an integrated JTAG programmer/debugger. If you would like to build your own board with an embedded programmer, things get a bit tricky.
In the case of the STMicroelectronics® popular ST-Link V2.0/V2.1 there are lots of clones out there, e.g. from eBay/AliExpress.
The maximum programming speed of those is 4 MHz. For larger projects, this can cause long upload times of up to a minute, which is not very pleasant while debugging a system.
The "new" ST-Link V3 does not have this issue and provides a Full-Speed USB interface, which leads to an upload speed of 24 MHz!
No ST-Link V3 clones available
In my latest project, I would like to implement an embedded ST-Link V3, but I couldn't find any resources of other people who have done that already.
Therefor, I've started reverse engineering things and created a proof of concept in the form of an external ST-Link V3 prototype.
Instead of developing only a cloned ST-Link V3, I decided to build a custom ST-Link V2 programmer in addition.
My goal was, that they share the same physical dimensions and are easily exchangeable.
Hardware Design
As reference for designing my own hardware, I used schematics of ST Nucleo boards:
ST-Link V2.1: NUCLEO-32 STM32G0 (MB1455)
ST-Link V3.0: NUCLEO-144 STM32H7 (MB1363)
Some pins of the onboard programmer are sadly not shown in this schematic. Luckily, some other guys on the EEV-Blog did already some reverse engineering of the pinout of the ST-Link V3 (EEV-Blog). Here is what they've come up with:
CN3-1 VDD CN3-2 PA14 (SWCLK) CN3-3 GND CN3-4 PA13 (SWDIO) CN4-1 GND CN4-2 nRST CN5-2 PB14 (USB DM) CN5-3 PB15 (USB DP) 1 PB11 Bridge UART RX(1) -> RX signals are inputs for STLINK-V3MODS, outputs for target. 2 PD11 Bridge UART CTS 3 PD12 Bridge UART RTS 4 PH7 T_JTMS/T_SWDIO 5 PG5 GNDDetect(2) 6 PC7 T_JTDO/T_SWO(3) 7 PA9 Bridge SPI CLK 8 GND GND 9 PA11 Bridge CAN RX(1) 10 PA12 Bridge CAN TX(4) 11 PC10 Bridge UART TX(4) -> TX signals are outputs for STLINK-V3MODS, inputs for target. 12 PG9 T_VCP_TX 13 PB3 T_JCLK/T_SWCLK (SWO) 14 PB4 Bridge SPI NSS 15 PG14 T_VCP_RX 16 PB6 Bridge I2C SCL 17 PB9 Bridge I2C SDA 18 PE2 Bridge GPIO0 19 PE4 Bridge GPIO1 20 PE5 Bridge GPIO2 21 PE6 Bridge GPIO3 22 (LoadSW out) Reserved(5) 23 PC1 Bridge SPI MISO 24 GND GND 25 PC2 Bridge SPI MOSI 26 GND GND 27 GND GND 28 PA1,PF8 T_JTDI/NC(6) 29 GND GND 30 T_VCC(7) 31 PA6 T_NRST 32 PA7 T_SW_DIR PA0 T_VCC (pin 30), divided down Load_EN PB0 (load_EN (w 10k pulldown) OSC 25MHz PH0 OSC-IN (VBUS detect?) PB1/ADC? (Vsw divided by (4.7k+2.7k)) LD1_1 PA10 (through 330 ohm) LD1_2 PA10 (through 330 ohm) LD1_3 GND LD1_4 VDD 3.3V LD2 ST-Link fault Load-switch Fault LD3 5V/VBUS? 5V power + resistor
Manufacturing
The PCBs have been manufactured and assembled by JLCPCB. All files are available to download below.
To save some production costs, I decided to combine both ST-Link versions on one PCB. They can be separated by breaking at the specified mouse bite holes.
The missing parts are hand placed and soldered with a heat gun.
Firmware
The firmware of the ST-Link consists of two parts: Bootloader and application code.
Bootloader
The bootloader makes it possible to upgrade the ST-Link firmware via USB and the STM32CubeProgrammer. The bootloader itself doesn't get updated or changed in this process. By running the bootloader code, the JTAG-SWD Readout-Protection gets activated, which means that the firmware can't be dumped later on.
A guy named lujji established to dump the bootloader by uploading a "fake" firmware which sends the whole Flash content via UART. He documented this process on his webpage here.
He reverse engineered the bootloader code and patched out the instructions which activate the Readout-Protection.
All different bootloader variants (protected and unprotected) can be downloaded...
Florian Baumgartner
Benjamin Vernoux
AVR
niwciu
Hi, I followed this project and did my own custom ST-Link V2.1 following your schematic for the custom ST-Link V2.1.
I have tried uploading the STLink-2_1_V2J37M26 (STM32+MSD+VCP).bin into the custom board using a ST-Link V2 with STM32CubeProgrammer. No errors while uploading, no errors afterwards, the red LED on the custom board blinks every second or so. I unplug everything and plug the custom board with USB-C to my computer and I get an error, USB peripheral not recognized. I have tried different ports, different USB-C wires, those are not the issue here. I have tried uploading the bootloader alone and then the firmware, same error.
Would you have any insight on what may be the issue?
The factory ST-Link V2 is functional and is easily recognized by my computer, but not the custom ST-Link.
