DIY Arduino Project - Creating an Illusion
Here will be giving you complete details including the circuit, the PCB files if you want to make a PCB and complete the code. I will provide all the resources so that you can redesign the entire thing, customize it and then make your own version of it. This project is really cheap, very easy to make and once you have all the components it won’t take more than 10 minutes to make one yourself.
DIY Arduino Project - Creating an Illusion – Complete Video Tutorial
My name is Jithin and I’m super excited to teach you everything you need to know about Arduino, Robotics, and other fun DIY hobby projects. If you are a true fan of Arduino and you are really interested in building amazing DIY projects, then this channel is for you. So make sure you subscribe to our channel by hitting the subscribe button here. Now, let’s get started with the project.
Why not make a PCB for your Project?
Making a PCB for your DIY project is not hard nowadays. PCB helps to get rid of all messy wires and stuff and gives your project an awesome look. And its cool to make your own PCB for your project right?
Ordering PCB
I usually order our PCBs from PCBWay. PCBWay is a PCB manufacturer specializing in PCB prototyping, low-volume production, and neat and tidy PCB Assembly for a very low price. They have a very friendly customer support team and even perform a free PCB Design Review before payment and inform us if there is some issue with the design. Feel free to check out their website below.
Make your own PCB for your Project
How does Time Catcher work?
In this project, we are actually creating an illusion by flashing the led in a particular frequency. The plan is to set the time period which is equal to something repeating itself.
For example in the case of this fan, we will be flashing this light whenever the blades come at a particular point. It is like taking a point in time snapshot of the object. If the frequency is equal to the frequency of the rotating fan, we will see the fan standing still and we will feel like it is frozen in time. If the frequency is a bit higher, we will feel like the fan is rotating backward. If the frequency is a bit lower we will feel like the fan is rotating forward. All you have to do is blink the LED with a frequency that is equal to or near the frequency of the object.
DIY Arduino Project - Creating an Illusion – Components Needed
To do this project all I used was -
- Arduino
- Accelerometer
- Light source – I tried with some 5 volts LED and a Neopixel ring
- 9 Volt Battery
Basically, that’s all we need.
Step 1 – The Circuit
Now let’s take a look at the circuit. And here we are in Altium designer. Here you will see a voltage is input terminal, Vin gloves, where I can connect a 9-volt battery or a DC power adaptor. This voltage input is connected to a 7805 voltage regulator which will convert an unregulated DC voltage of 7 to 32 volt to 5 volt DC power supply. This 5 V is then connected to Arduino and Indicator LED as well as the accelerometer.
Get Complete Details about Circuit and PCB Layout from Arduino LED Projects Here.
I personally like PCBs. PCBs are neat and help to get rid of all nasty wires hanging around. And it’s cool to make your own PCBs for your project right. I used Altium designer to draw the circuit nd design the PCB. It is a powerful tool that can be used to design and create your own PCBs for your project as well as complex and multiplayer PCBs for industrial use.
Step 2 – Ordering PCBs from PCBWay
I ordered my PCB from PCBWay. PCBWay is a PCB manufacturer specializing in PCB prototyping, low-volume production, and neat and tidy PCB Assembly.
To order your PCB from the PCBWay, Go to the PCBWay website and fill in the basic board details in the instant order form. From there you will be directed to a form where you can provide more elaborate board details. Update your board...
Jithin Sanal
