Standard Tesselated Geometry - 18.76 MB - 04/21/2021 at 12:39 |
Pupabot_Chassis_Seperate1.stlPart 1/2The gcode for this one was too big Infill 15%, 2mm layer height, 65% overhang tree supports touching build plate, everything else default CURA settings for UM2+ Standard Tesselated Geometry - 7.04 MB - 04/21/2021 at 12:38 |
Pupabot_Chassis_Seperate2.stlPart 2/2Standard Tesselated Geometry - 2.82 MB - 04/21/2021 at 12:38 |
UM2_Pupabot_Chassis_Seperate2.gcodePart 2/2The gcode for part 1/2 was too big, see STL description. For um2+ gcode - 22.28 MB - 04/21/2021 at 12:39 |
postscript - 319.94 kB - 04/21/2021 at 12:38 |
