upcycled HDD turbo Solder Fume Extractor
A printed fan, filter mat and an old HDD keeps the solder fume away
jj
Public Chat
0 followers
Some old HDD plus this turbo fan (https://www.thingiverse.com/thing:4796289) makes an excellent fume extractor. I had to print the fan 130 % larger, so it fits the 3,5" axis. Its a bit oversized, so better use 128% instead. It is balanced after ftteling around.
The motor is been driven by a cheap 10A ESC.
A PIR (IR) sensor activates the motor for 10 seconds, if no further movement is registered.
The air flow is impressive !
Its handy, could been fed by a 2S LiPo and is good to have.
NEW:
- Speed Control throu fader
- RGB LED - indicates countdown time. From Green to Red = 20 s to 0 s
- No delays(); timer based .
ino - 1.06 kB - 04/22/2021 at 19:36
Download
Jacques Pelletier wrote 04/24/2021 at 08:42 point
It would be the ideal project to try the Tesla pump principle!
j wrote 04/24/2021 at 10:53 point
Nice idea! A HDD-Case could be seald up. I'm not shure about the sealing of the motor. The ingress of fluids could be problematic.
