The Scope reveals all
A project log for Radar Sensor
This project will be using an InnoSent IPM 165C and / or IVS 362 module to sense distance and motion towards / away from the observer.
capt-flatus-oflahertyCapt. Flatus O'Flaherty ☠ 05/10/2021 at 00:480 Comments
This is pretty much the expected result for non-Doppler static object detection, so all is good. Next task is to get this waveform into a RPi via an ADC without turning it into toast. Some lowering of the voltage and removal of DC offset may be required. Then, a bit of Fourier transform magick to pull out the hidden frequency and amplitude elelments.
